Re: Hemi into 383 Barracuda engine bay
[Re: nz383man]
#985927
05/04/11 08:58 AM
05/04/11 08:58 AM
Posts: 4,916 new berlin wisconsin
Mr T2U
there isn't any difference under the hood on E bodies. you might have problems with the right valve cover hitting the shock tower, under hard acceleration, if you use taller cast covers. also don't use 2 1/4" tube headers if you want to run power steering, hits the box.
perception is 90% of reality
[Re: Mr T2U]
#985928
05/04/11 09:16 AM
05/04/11 09:16 AM
Posts: 520 New Zealand
nz383man
New Zealand
Cheers for that Mr T2U I don't think I'll be doing too much hard acceleration and the covers I have at the moment are quite low just like the factory single plug ones. My car does not have power steering, but I'll probably go with 2 1/8" rather than 2 1/4" headers.
[Re: Triggerfish]
#985932
05/04/11 01:13 PM
05/04/11 01:13 PM
Posts: 4,848 Memphis
HemiRick
Memphis
The engine compartment is the same, but the crossmember the engine sits on is NOT. You will need a Hemi K member or some type of conversion engine mount, the problem w the conversion mounts is finding headers to work with them.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
