stroked sb Q #98559
08/02/08 12:44 PM
08/02/08 12:44 PM
The Sunny Shuswap
dodgefarmer Offline OP
The Sunny Shuswap
Has anybody managed to get a stock windage tray to clear the rods in a 408 small block with stock rods?
Randy
Re: stroked sb Q [Re: dodgefarmer] #98560
08/02/08 03:09 PM
08/02/08 03:09 PM
Philadelphia
radar Offline
radar  Offline
Philadelphia
Yeah, I just built a 408 out of a 360. The 360 was a windage tray 4bbl motor from the late 70s (cop car?).
I used eagle rods (I beam, not H) and it was all good. The only difference is the cap screws instead of nuts and bolts, I think.
Close, but doesn't hit.
Kevin
Re: stroked sb Q [Re: radar] #98561
08/02/08 06:51 PM
08/02/08 06:51 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
If you use ARP main stud kit, part number 240-5501, four of the studs are long so you can mount the windage tray lower. The longer studs allow you to sandwich the tray between two nuts allowing you to lower/raise the tray to where you want it. You should have the block line honed if you switch to the studs though.
Re: stroked sb Q [Re: 69Cuda340S] #98562
08/02/08 06:57 PM
08/02/08 06:57 PM
The Sunny Shuswap
The Sunny Shuswap
Thanks for the reply's guys but this thing is all together and I think my buddy will make a doorstop out of the tray before he rips the engine down and spends another couple of bucket loads of cash on it.
Randy
Re: stroked sb Q [Re: dodgefarmer] #98563
08/02/08 09:42 PM
08/02/08 09:42 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
In that case just leave it off.
