Eddy Carb Issue #985470
05/03/11 03:43 PM
05/03/11 03:43 PM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
I'm a holley guy, so I'm hoping you guys can help me diagnose this problem.
I've got a 318 with a standard eddy 600cfm carb. After about 4 days of sitting, the carb doesn't have fuel coming out of the squirters when I pump it to start the motor. I have to spin it long enough for the fuel pump to fill the bowl- then it fires right up. Is there a common place for these carbs to be losing fuel this slowly? It doesn't seem to be a problem until about after 3-4 days.
Thanks fellas
Re: Eddy Carb Issue [Re: mopowers] #985471
05/03/11 03:47 PM
05/03/11 03:47 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Welcome to the world of Eddybrock carbs and todays gas. Yes it is very common.
Coming soon!!!!
Re: Eddy Carb Issue [Re: Mr.Yuck] #985472
05/03/11 03:54 PM
05/03/11 03:54 PM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
Does it evaporate from some orifice or something? Should I rebuild the carb, buy an electric fuel pump, or deal with the hassle of cranking the motor for days until she fires?
Re: Eddy Carb Issue [Re: mopowers] #985473
05/03/11 03:56 PM
05/03/11 03:56 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I'd just deal with it. An electric pump is overkill. It helps if you have the air cleaner assembly on.
Re: Eddy Carb Issue [Re: Mr.Yuck] #985474
05/03/11 04:13 PM
05/03/11 04:13 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
It's not just not just a eddy/carter carb problem it's the current BLEND and all carbs. An electric pump would be a way around it , you turn on the pump and it fills the carb , should light right up .
Re: Eddy Carb Issue [Re: JohnRR] #985475
05/03/11 05:17 PM
05/03/11 05:17 PM
Missouri
bb74swngr Offline
mopar addict
bb74swngr  Offline
mopar addict
Missouri
It's not just not just a edby/carter carb problem it's the current BLEND and all carbs. An electric pump would be a way around it , you turn on the pump and it fills the carb , should light right up .
I did what johnrr suggested and works great!
BigBlock 74 Swinger
Re: Eddy Carb Issue [Re: bb74swngr] #985476
05/03/11 05:23 PM
05/03/11 05:23 PM
P
Paul_Fancsali Offline
P
Buy a part store elec fuel pump cheapie they will fill the fuel bowls and do not need a regulator. Advance used to have one fairly cheap
Re: Eddy Carb Issue [Re: Paul_Fancsali] #985477
05/03/11 05:30 PM
05/03/11 05:30 PM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
You can also install a fuel filter with a return line fitting and run a 1/4" fuel line back to the tank. As the gas heats and expands when the car hotsoaks, it will allow some of it to push back to the tank.
Yes, an electric pump will solve the symptom, but a return line will save some of the fuel.
I saw a realy explanantory magazine article on this a few years ago, a netsearch might find it for you.
Re: Eddy Carb Issue [Re: bb74swngr] #985478
05/03/11 05:57 PM
05/03/11 05:57 PM
JohnRR Offline
JohnRR  Offline
I'm considering doing this on any car I have now wit ha manual fuel pump , I don't trust the ethanol in the fuel and that it could eat thru the rubber diaphragm and fill the crank case with fuel.
Re: Eddy Carb Issue [Re: JohnRR] #985479
05/03/11 07:14 PM
05/03/11 07:14 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
you'll be fine. you never drive your car anyway
Coming soon!!!!
Re: Eddy Carb Issue [Re: JohnRR] #985480
05/03/11 07:22 PM
05/03/11 07:22 PM
scratchnfotraction Offline
thats the main reason i went with the elect fuel pump set up on my 440 truck,had this happen 2x already on BB engines.
i lost the first one with a spun rod bearing,then figured it out when I smelled gas in the oil on the second engine.
not going there on this 3rd 440
Re: Eddy Carb Issue [Re: mopowers] #985481
05/03/11 07:27 PM
05/03/11 07:27 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I use a stock style air filter which I think helps keep the bowl vents covered better than a open air filter. I've been running the same carb for 20+ years. It's a little tougher to start with todays blended gas. When I'm at home with the car I don't used blended gas. Makes a big difference for me. When I'm out of town with it I have to buy blened gas.
I just started my 74 with a 1405 600 eddie carb on it last week one day. The car has sat since around Nov last year. It fired up after about 8-10 seconds crank time, just like always. This is the same carb that sat all through the 90s and maybe getting started once a year, haven't even rebuilt it.
Re: Eddy Carb Issue [Re: Challenger 1] #985482
05/03/11 07:47 PM
05/03/11 07:47 PM
Might try one of those thick Felpro square base gasket iirc ~3/8" for more insulation or a black phenolic 4 hole spacer of what ever thickness your hood w allow & reportedly those are a very good addition to an Eddy
Re: Eddy Carb Issue [Re: RapidRobert] #985483
05/03/11 09:41 PM
05/03/11 09:41 PM
desomod Offline
desomod  Offline
The problem with an elecrtic fuel pump is that you need to get it lower than the level of the fuel tank so that it too doesnt go dry. They don't suck, they push (which really sucks!).
Has anyone solved this or has anyone come up with a "in tank" electric pump like with modern cars that doesn't require cutting the tank apart?
Re: Eddy Carb Issue [Re: desomod] #985484
05/03/11 10:03 PM
05/03/11 10:03 PM
Cincinnati, Ohio
chargincharles Offline
Cincinnati, Ohio
All modern fuels do this...as others have said.
You can get a small 'booster' electric fuel pump that mounts inline. Mount it on the fuel line, inside the frame rail midway between the engine and the tank and it will always be below the tank level.
To answer your question- the fuel is evaporating out of the float bowl vent- which is on the top of the carb.
And- use a think base gasket- the black rubberish ones work well, or a phenolic one is ideal. Eddy's don't like heat- it will evaporate the gas FASTER if you don't have one.
Yeah- modern gas is the worst! Thank You Mr. EPA....
If your a holley guy your going to be amazed how easy it is to work with the Eddys. Much much easier to tune/alter for your application.
Good Luck,
CC.
Re: Eddy Carb Issue [Re: chargincharles] #985485
05/03/11 11:18 PM
05/03/11 11:18 PM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
Its funny alot of you say its the fuel, hmmm, i remember having the same problem with any eddy carb i ran as far back as the early 90s, after a good week the carb would damn near go dry, Whats ironic is i never had that problem like this with any holley i've ever used & i've used alot of them (unless the gaskets were leaking), my last 3 holleys were on my 360 magnum just last year, that car would sit a good 2 weeks at times (summer or winter) didn't matter on todays blends, the bowls would always hold plenty of fuel .
I do agree todays blends have a lower boiling point, but i don't think by much.
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
Re: Eddy Carb Issue [Re: joedust451] #985486
05/03/11 11:25 PM
05/03/11 11:25 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
the well for the accelerator pump sits up higher then the floor the bowl in the eddy carb...
they is still gas in the bowl..but the pump goes dry due to evaporation of our 4.00 a gallon gas.
holley feeds the accelerator pump from the bottom of the bowl...so the holley will not that the same problem as fast as the eddy carb does..
I park my duster facing down the drive way ...gravity helps the eddy carb...LOL
Tony
70 AARCuda Vitamin C
Re: Eddy Carb Issue [Re: 70AARcuda] #985487
05/03/11 11:58 PM
05/03/11 11:58 PM
Have to try that
Re: Eddy Carb Issue [Re: chargincharles] #985488
05/04/11 12:56 AM
05/04/11 12:56 AM
Saint Louis, MO
jjschm Offline
jjschm  Offline
Saint Louis, MO
CC, what brand/model electric 'booster' pump do you recommend? I have the exact same issue with my set up (318, Eddy600, the regular fuel pump) but was afraid an electric would push too much pressure to the Eddy carb. To you keep the stock pump with the booster?
Thanks,
Jon
Re: Eddy Carb Issue [Re: joedust451] #985489
05/04/11 08:31 AM
05/04/11 08:31 AM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
I have limited experience with the Eddy carbs. I've had 2 different Holleys on my BB, a 750 vac sec and a 800 double pumper. The last 2 winters(one with each carb)I parked the car in Oct-Nov and didn't touch it till April. Both times I popped the air cleaner,looked down the carb throat and sure enough....squirt,squirt. Few cranks and it lit right up!
