Page 1 of 3 1 2 3
Burnt cups....again... #985327
05/03/11 02:18 AM
05/03/11 02:18 AM
NE Oklahoma
V
Von Offline OP
Von  Offline OP
V
NE Oklahoma
Built another 440 to put in another car Im building. That car isnt finished so I stuck it in my car. Due to being pissed, gunshy, sick, etc of burning up cups, I made damm sure on this motor that the cam bearing was in the right place, no obstructions in the block or heads, etc. I also filled the feed holes for the tips on the rockers...and also cut a connecting groove in the rockers from the oil band to the feed hole to the cup. Checked on the stand and oil was gushing out of the back of the rockers....Plenty of oil to the top.......
Get the cam broke in, set lash again. Drive it, 20 or so miles. Hear a noise under both valve covers. Praying its just the rockers. (A little loose on side clearance). Drive 30 or so more miles and decide to put the inner springs back in. 50 FLIPPIN miles. 2 cups toasted and another showing signs of heat. All 3 on exhaust...same deal as my other motor. Most of the problems with it were on exhaust. A few intakes showed heat, but never blued very bad. These 3 are burnt to a crisp....worst Ive had so far. #1 exhaust was burnt....OK...maybe I was loosing too much oil from the excessive side clearance in the rockers. But, on the other side, #4 was cooked, and #8 showed signs of heat. So, that blew my first thought...
The oil in the car is a mixture of old rotella and oil that a local shop has formulated for them, for dyno use. Id say 2k or more PPM of zinc.
Spring pressure was only 300 or so open, nothing close to heavy. Cam is only a XE282S, puny little thing...
Old style Hughes rockers, which I think are the same as the blue indy rockers...
I noticed on the stand that the pushrods were a hair too short. Id say they need to be .050 or so longer, but they arent super short. Again, I'll say that the X amount of threads sticking out of the adjuster is meaningless. I have 1.5 sticking out and it probably needs to be 0 out, but cmon....
So, what have I missed??
I have a set of HS rockers that are going on next...I keep hearing run the HS, it will fix your problems...I guess we will flippin see...
Any ideas welcomed!! I'll even take a few sticks of dynomite..
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: Burnt cups....again... [Re: Von] #985328
05/03/11 04:02 AM
05/03/11 04:02 AM
renton , washington
P
perfmachst Offline
perfmachst  Offline
P
renton , washington
hi, question,?? what did you lube cups with on assembly?? oil or grease?? just curious.
Re: Burnt cups....again... [Re: perfmachst] #985329
05/03/11 07:55 AM
05/03/11 07:55 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Check the inside bore of the rockers for a full oil groove that direct the oil to the pushrod passage.We have found Dove rockers with out the oil groove and had the same issues.
Re: Burnt cups....again... [Re: Von] #985330
05/03/11 09:37 AM
05/03/11 09:37 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I dont know the Hughs rockers but does it have a hole
that shoots oil at the cup OR does it oil through a
hole in the adjuster
Re: Burnt cups....again... [Re: MR_P_BODY] #985331
05/03/11 09:50 AM
05/03/11 09:50 AM
NE Oklahoma
V
Von Offline OP
Von  Offline OP
V
NE Oklahoma
Shoots oil at the cup.
Re: Burnt cups....again... [Re: Von] #985332
05/03/11 09:56 AM
05/03/11 09:56 AM
Left Coast
BobR Offline
BobR  Offline
Left Coast
The feed hole on the shaft turned down? The pushrod length correct?
I hate the way these oil. Sometimes it just happens.
Re: Burnt cups....again... [Re: Von] #985333
05/03/11 10:32 AM
05/03/11 10:32 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I thought 2 to 3 threads was ideal , if you go to 0 wouldn't the cups hit the rocker body?
Are your pushrods ball/cup or did you switch to ball ball and cups on the rockers ?
Re: Burnt cups....again... [Re: Von] #985334
05/03/11 10:41 AM
05/03/11 10:41 AM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
Von..
Throw up a picture ir two if you can. These are two totally different engines right?
RIP Monte Smith
Re: Burnt cups....again... [Re: Von] #985335
05/03/11 12:32 PM
05/03/11 12:32 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I believe it's gonna be a difference in cup and ball size. I bet if you look real close the ball is not fitting in the cup correctly, not enough contact area causing overheating because only a small area of contact. imo
And the only lube I would use at first start up is black moly lub.
Best to buy those 2 things(adjuster and cups) from someone like Smith Brothers so you know what you have, size and hardening. There are different ball and cup sizes.
Re: Burnt cups....again... [Re: Challenger 1] #985336
05/03/11 01:07 PM
05/03/11 01:07 PM
organ
maximum entropy Offline
organ
And the only lub I would use at first start up is black moly lub.
Best to buy those 2 things from someone like Smith Brothers so you know what you have, size and harding. There are different ball and cup sizes.
this is my guess as well.
Re: Burnt cups....again... [Re: maximum entropy] #985337
05/03/11 01:49 PM
05/03/11 01:49 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Get a new set of adjusters that have a hollow hole in them. I know Jesel has them, thats what comes on there stuff.
I have had better luck with the cup adjusters and ball end-ball end pushrods.
It isnt very hard to add a spray bar under there either. This would sure eliminate the problems.
I made my own spray bar setup with 3/16 inverted flare brake fittings, and a little imagination.
Good Luck
Re: Burnt cups....again... [Re: Bob_Coomer] #985338
05/03/11 04:25 PM
05/03/11 04:25 PM
Ontario, Canada
Stanton Online content
Don't question me!
Stanton  Online Content
Don't question me!
Ontario, Canada
I've never understood the point of a cup adjuster/ball pushrod in a performance application. Gravity causes things to run downhill ... including oil. Add spring pressure to that and I just can't see how this style would ever get lubtricated! At least with a cup-style pushrod oil will tend to want to sit in it.
Re: Burnt cups....again... [Re: Stanton] #985339
05/03/11 05:38 PM
05/03/11 05:38 PM
MR_P_BODY Offline
MR_P_BODY  Offline
All the big dollar stuff has the cup adjuster with a
oil hole in the cup... the oil is right there... not
spraying oil at the area
Re: Burnt cups....again... [Re: Challenger 1] #985340
05/03/11 06:45 PM
05/03/11 06:45 PM
Livonia Michigan
440dart Offline
440dart  Offline
Livonia Michigan
I had this same problem, and I went with Smith Bros. adjusters and push rods, PROBLEM SOLVED. Do they look like this
Yes I live in Michigan, so there is still 1 light on
Re: Burnt cups....again... [Re: 440dart] #985341
05/03/11 07:45 PM
05/03/11 07:45 PM
Clinton Township, Michigan
Dartin Offline
Dartin  Offline
I experienced the same thing with my motor, twice. It is very frustrating. Next time around I will go with ball/ball pushrods and oil through the adjusters or the pushrods.
Randy
Re: Burnt cups....again... [Re: Dartin] #985342
05/03/11 07:55 PM
05/03/11 07:55 PM
Cincinnati Oh
fasthawk6 Offline
fasthawk6  Offline
Cincinnati Oh
T&DS solved my same promblem
Re: Burnt cups....again... [Re: fasthawk6] #985343
05/03/11 09:40 PM
05/03/11 09:40 PM
mckinney texas
shoebox Offline
shoebox  Offline
mckinney texas
Ive got a question..... Can you have the cup adjuster and ball/ball pushrod
And NOT have "pushrod oiling"? Where do the hollow smith bros cup adjusters get oil from?Im going with normal HS rockers.... Do
Those have these problems? Thanks
74 dart sport 440 www.Csucarbs.com
Re: Burnt cups....again... [Re: shoebox] #985344
05/03/11 09:47 PM
05/03/11 09:47 PM
MR_P_BODY Offline
MR_P_BODY  Offline
That depends on weather the rocker is made for the cup
and cup oiler, but to just change over wont work
Re: Burnt cups....again... [Re: MR_P_BODY] #985345
05/04/11 12:42 AM
05/04/11 12:42 AM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
Von,
Those Erson Rockers I sent you have the correct adjuster to run ball ball pushrods. Look those over real careful and make the changes to the other rockers. The ball ball adjuster came from Jesel I believe.
PROBLEMS OVER!!!
Re: Burnt cups....again... [Re: Biginchmopar] #985346
05/04/11 10:39 AM
05/04/11 10:39 AM
NE Oklahoma
V
Von Offline OP
Von  Offline OP
V
NE Oklahoma
I discussed this with Dwayne a month or so ago. Basically you get the pushrod length set to where the feed hole has a straight shot at the cup...and the number of threads or lackthereof, falls where it may. I knew the pushrods Im using are a hair short, but nothing major.
And no, at 0 threads it wont be hitting the rocker body..
Cup pushrods, ball adjusters.
Ive stripped the Hughes rockers off, and thrown them in a box. Last night I put a set of HS rockers on, and ran the drill to see what the oiling looks like. I have tested 6 different brands of rockers over the past 8 months or so. The HS rockers are the ONLY ones that when oil is running out of the feed hole, it actually hits the screw/cup. All the others, oil would just run down the back of the rocker. I could still use a hair longer pushrod to have the relationship between the cup and feed hole ideal, but I'll run it a few miles and see what happens..........
Page 1 of 3 1 2 3
