What is the best alternator bracket w/motor plate? #985251
05/02/11 11:41 PM
05/02/11 11:41 PM
VT
MOPARCRAZY Offline OP
VT
I have 69 Dart with RB and I am changing to a front motor plate. What is your alternator and bracket solution with the motor plate?
Thanks,
Lon
Re: What is the best alternator bracket w/motor plate? [Re: MOPARCRAZY] #985252
05/03/11 01:10 AM
05/03/11 01:10 AM
AndyF Offline
AndyF  Offline
Very common question. A search should find multiple threads with pictures.
Re: What is the best alternator bracket w/motor plate? [Re: AndyF] #985253
05/03/11 04:31 AM
05/03/11 04:31 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
easy
Re: What is the best alternator bracket w/motor plate? [Re: MOPARCRAZY] #985254
05/03/11 06:48 AM
05/03/11 06:48 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Jegs bracket and some pulleys that work...Shorter the belt, the tougher it is to not have it slip, that is why mine is 8mm cog....
Re: What is the best alternator bracket w/motor plate? [Re: MOPARCRAZY] #985255
05/03/11 08:27 AM
05/03/11 08:27 AM
tboomer Offline
tboomer  Offline
DMI here by Mike Doty...
Re: What is the best alternator bracket w/motor plate? [Re: MOPARCRAZY] #985256
05/03/11 11:21 AM
05/03/11 11:21 AM
Central Oregon
Rodney Offline
Rodney  Offline
Central Oregon
We've used this one from DMI has worked well with a small alternator on our GTX 500 cu in.
Re: What is the best alternator bracket w/motor plate? [Re: Rodney] #985257
05/03/11 08:58 PM
05/03/11 08:58 PM
VT
VT
Thanks!
I called DMI and they have one to fit the Indy timing cover too! Mine is on the way. Nice people to talk to.
Thanks for the help.
Re: What is the best alternator bracket w/motor plate? [Re: Dragula] #985258
05/03/11 10:34 PM
05/03/11 10:34 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Randy,is that the large GM or small alternator??I need to relocate my alternator and that Jegs bracket looks perfect!
http://www.jegs.com/i/JEGS-Performance-Products/555/50542/10002/-1
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: What is the best alternator bracket w/motor plate? [Re: hemi-itis] #985259
05/04/11 12:24 AM
05/04/11 12:24 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I machined up a spacer to attach to the water pump bolt. Then I ground a adjustment slot in the motor plate.
Doug
Re: What is the best alternator bracket w/motor plate? [Re: hemi-itis] #985260
05/08/11 10:29 PM
05/08/11 10:29 PM
Franklin Furnace, OH
moparman1954 Offline
where did you get the cog?
