Reuse old torsion bars or buy new? #985225
05/02/11 11:17 PM
05/02/11 11:17 PM
Michigan,United States
barracudadon383 Offline OP
I'm restoring my '68 Barracuda and was wondering if the original torsion bars can be reused or if I should buy new. My car came with a big block and has the .89 size bars. The big block was taken out way back in 1974 and replaced with a 318 and was driven mostly by an old lady so it wasn't hot rodded for at least those years. If the originals could be used I would like to use them but was wondering what everyone's opinion on this is. Thanks...
Learnin' the hard way...
Re: Reuse old torsion bars or buy new? [Re: barracudadon383] #985226
05/02/11 11:23 PM
05/02/11 11:23 PM
SD
Z
zrxkawboy Offline
zrxkawboy  Offline
Z
SD
If they are in good condition, I'd reuse them.
It's Swifty! Swifty, you toad sucker!
Re: Reuse old torsion bars or buy new? [Re: barracudadon383] #985227
05/03/11 12:23 AM
05/03/11 12:23 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
new......come on
Re: Reuse old torsion bars or buy new? [Re: DAYCLONA] #985228
05/03/11 03:04 AM
05/03/11 03:04 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I reuse them all the time as long as they are in good contition. Even the ones in my 63 are original and I have never had any break on me. Ron
Re: Reuse old torsion bars or buy new? [Re: 383man] #985229
05/03/11 03:33 AM
05/03/11 03:33 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
My thoughts are that if you are going for a stock restoration, only the factory bars would be correct. I went from a 318 to a 440, and I wanted improved handling at the same time. I chose to go with larger T bars. If yours are not bent and the hex ends are still in alignment with each other, then they would be fine to reuse. Lay them on a bench or table. If both ends sit flat on the surface, your golden.
Re: Reuse old torsion bars or buy new? [Re: barracudadon383] #985230
05/03/11 06:12 AM
05/03/11 06:12 AM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
Hey it's your money, why not.
Seriously, I'd reuse them. I've never had a single one break and yours weren't even supporting a big block over most of its life.
Re: Reuse old torsion bars or buy new? [Re: Dean_Kuzluzski] #985231
05/03/11 08:39 AM
05/03/11 08:39 AM
That's pretty much exactly what I was thinking. I'll have to check for alignment Like you said, but I think they should be good. I am looking to keep or return everything to stock so I'm hoping they will be good. Thanks for the thoughts...keep 'em comin'.
Re: Reuse old torsion bars or buy new? [Re: barracudadon383] #985232
05/03/11 08:43 AM
05/03/11 08:43 AM
Yea, beside I am just a working stiff and I don't have a bottomless checkbook.
