high Air flow Aluminum air cleaner bases? #985100
05/02/11 08:24 PM
05/02/11 08:24 PM
fullmetaljacket Offline OP
Who makes an air cleaner drop base that has smooth high flow edges to help in carb breathing?
Re: high Air flow Aluminum air cleaner bases? [Re: fullmetaljacket] #985101
05/02/11 08:44 PM
05/02/11 08:44 PM
Sask, Can.
72demon416 Offline
72demon416  Offline
Sask, Can.
Universal spinners....but the nice smooth entry is raised somewhat high up so it cuts into the useable area of your filter. If hood clearance or filter height isn't a issue it's a nice piece.
Re: high Air flow Aluminum air cleaner bases? [Re: 72demon416] #985102
05/02/11 09:12 PM
05/02/11 09:12 PM
Locomotion Offline
Locomotion  Offline
Proform has a similar unit. Proform Parts 66808
Search "drop base" on the Summit site for it and other versions. (DragRaceCentral.com)
Re: high Air flow Aluminum air cleaner bases? [Re: 72demon416] #985103
05/02/11 09:21 PM
05/02/11 09:21 PM
Thank you gents. I have no hood issues cause I run outlaw A-990 AFX hood scoop and have a good amount of real estate clearance.
Re: high Air flow Aluminum air cleaner bases? [Re: fullmetaljacket] #985104
05/02/11 10:08 PM
05/02/11 10:08 PM
acworth / N. georgia - south e...
cheapstreetdustr Offline
the drop or curved architecture works best ..
to manage air entering the carb..
do the drop bases..have good throttle lever clearence..?
float screw clearence?
chepast
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured
[image][/image]
Re: high Air flow Aluminum air cleaner bases? [Re: cheapstreetdustr] #985105
05/02/11 10:12 PM
05/02/11 10:12 PM
I have clearance on the fuel lines cause I am running the Aeromotive adjustable fuel log that rides low in the hole, regular fuel bowls, and throttle levers.
Re: high Air flow Aluminum air cleaner bases? [Re: fullmetaljacket] #985106
05/02/11 11:36 PM
05/02/11 11:36 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Got this from Hoerr Racing Products (HRP)a few years back.
Re: high Air flow Aluminum air cleaner bases? [Re: BSB67] #985107
05/03/11 06:51 AM
05/03/11 06:51 AM
Utah
topbrent Offline
topbrent  Offline
Utah
Here: HRP 14" Air Cleaner Base
HRP air cleaner page
Available in 14" and 16"
