How much does ignition timing affect 1/4 mile MPH.
#984830
05/02/11 01:02 PM
05/02/11 01:02 PM
Posts: 288 Birmingham, England
Mick70RR
Birmingham, England
I went down to the local drag strip on Saturday and my times were 3 or 4 MPH down. Checked the ignition timing today and it was set at 32 degrees max, I normally run 38 degrees. Don't ask how this happened. I also did a compression test to see if anything was up but all cylinders were within 5psi of 200psi. Engine is a 440 stroked to 505, 10.3:1 compression with the Mopar 528 solid cam. Just wondering if the ignition timing would affect power this much?
1970 Road Runner
505 cid
MCH CNC ported Stealth heads
MP 528 camshaft
4 speed
GV overdrive
11.98 @ 117 on street treads
Re: How much does ignition timing affect 1/4 mile MPH.
[Re: Mick70RR]
#984831
05/02/11 01:24 PM
05/02/11 01:24 PM
Posts: 3,300 Northern Indiana
Dunnuck Racing
Northern Indiana
I would bet that was at least the majority of the car's slowing down. The 440 I have been dyno testing lost an average of 10 horsepower going from 38 to 36 degrees.And adding or subtracting just 1 degree from the 38 that it ran best at lost about 5 hp on average. I could believe it.I read a test result on a pretty well sorted out small block somebody else did that lost 30 hp with a 1 or 2 degree change,30 hp should be around 3 tenths on an average car. Keith
[Re: Mick70RR]
#984833
05/02/11 02:05 PM
05/02/11 02:05 PM
Posts: 549 Bristol, Va
fasteddie
Bristol, Va
I don't know about a 440, but my 360 with shaved J heads to make a small chamber with .045 quench and flat top pistons slows down with more than 28 degrees timing. I have tested and verified it twice.
2003 Bristol Dragway Sportsman Champion
2016 Bristol Dragway Power Hour Champion
[Re: MR_P_BODY]
#984834
05/02/11 02:27 PM
05/02/11 02:27 PM
Mick70RR
Birmingham, England
There was a strong head wind also but I doubt enough to account for such a drop in MPH. I've raced into head winds before and never noticed much difference. The car usually runs 115/116 MPH but was down to 111 MPH on Saturday.
1970 Road Runner
505 cid
MP 528 camshaft
4 speed
GV overdrive
[Re: Mick70RR]
#984836
05/02/11 02:41 PM
05/02/11 02:41 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I think its a combination of both... I've pulled timing before to slow the car down some and had minimal effect... I was trying to slow it .2 and didnt get it... that was 5* and got about.1
[Re: MR_P_BODY]
#984837
05/02/11 02:57 PM
05/02/11 02:57 PM
Posts: 7,506 Az
Crizila
Az
Don't count out a change in DA also. Quite often when you have a big wind, the DA is bouncing all over the place also.
Fastest 300
[Re: Mick70RR]
#984838
05/02/11 04:58 PM
05/02/11 04:58 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
What were your 60' times, 660 times and 1320 times as compared to your previous runs. The timing usually shows up very early in the run..IE 60'.
What was the DA vs previous runs?
RIP Monte Smith
[Re: CompWedgeEngines]
#984839
05/02/11 05:26 PM
05/02/11 05:26 PM
Mick70RR
Birmingham, England
No idea what the DA was, I'm not a serious racer, just like to run the car every month or so during the summer but the car is more street than strip and driven most days. 660 MPH was also down on what it usually runs, 87 MPH compared with a best of 92 and an average of about 90. 60 foot times are a bit hit and miss with this car, it's a 4 speed, didn't notice much difference on Saturday.
1970 Road Runner
505 cid
MP 528 camshaft
4 speed
GV overdrive
[Re: 540DUSTER]
#984841
05/02/11 06:21 PM
05/02/11 06:21 PM
Mick70RR
Birmingham, England
The timing didn't change, I set it myself incorrectly, just a stupid mistake.
1970 Road Runner
505 cid
MP 528 camshaft
4 speed
GV overdrive
[Re: 540DUSTER]
#984842
05/02/11 07:16 PM
05/02/11 07:16 PM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
According to Don at FBO, a BB mopar WILL NOT make any more power with more than 34 degrees...... I asked for an explanation (even though I knew better than to ask/argue with him). The explanation was one that only polyspheric could understand.....lol. I guess Im just lucky that going to 38 has almost always gained me some MPH. CMON MAN.......
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
[Re: Von]
#984843
05/02/11 07:21 PM
05/02/11 07:21 PM
Quicktree
CMON MAN.......
yea I have to call BS on the 34* also.
[Re: Quicktree]
#984845
05/02/11 09:55 PM
05/02/11 09:55 PM
Posts: 415 Peru
cbarracuda
Peru
CMON MAN.......
[Re: Chris'sBarracuda]
#984847
05/02/11 10:11 PM
05/02/11 10:11 PM
Posts: 19,377 Las Vegas
Al_Alguire
Las Vegas
From my experience you will loose more ET than MPH by retarding timing. You will loose some MPH but ET seems affected more. As pointed out wearlier it usually shows up early in the run. Headwinds can KILL MPH as well. So IMO put it back and go run it.
