LH rack
#984825
05/02/11 01:01 PM
05/02/11 01:01 PM
Posts: 905 SD
zrxkawboy
SD
I'd like to hear from anyone who has replaced the rack & pinion in a 1st generation LH car. I've read the procedure, but would like to hear from someone with first-hand experience. How difficult was it? Roughly how long did it take? Thanks!
It's Swifty! Swifty, you toad sucker!
Re: LH rack
[Re: gtx6970]
#984827
05/02/11 11:34 PM
05/02/11 11:34 PM
Posts: 905 SD
zrxkawboy
SD
Thank you for the reply. The service manual procedure says to remove the shift cable and also a "travel sensor" on the brake booster. Are these steps necessary?
Re: LH rack
[Re: zrxkawboy]
#984828
05/03/11 07:57 AM
05/03/11 07:57 AM
Posts: 21,403 It's a dry heat
gtx6970
It's a dry heat
The travel sensor is if I remember right ABS only and and I don't remember ever removing one, so I can't answer that one. BUT, It might be best to do so, for a newbie to avoid breaking parts.
Best I remember , Shift cable can be left in and just run the rack all the way to the pass side. Once done there is a rubber boot on the ends of the rack itself that can be folded in to gain clearence.
Also, I usually remove the tie rod ends at the ceneter attaching point on the rack to ease in removal and install. So that may be why I get them out without removing the shift cable.
