Re: 2005 neon engine vibration
[Re: 70SportSatellite]
#984814
05/02/11 08:59 PM
05/02/11 08:59 PM
Posts: 12,260 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I would check the other mounts to make sure they aren't letting the engine get out of position. If the other mounts aren't too bad, then try loosening up the new mounts and moving the engine around to see if the vibration goes away.
The mounts have slots rather than holes that allow for a limited range of positions when torqued down. A floor jack under the engine helps.
Master, again and still
#984815
05/02/11 09:31 PM
05/02/11 09:31 PM
Posts: 2,928 A tad North of Indy
Blown71X
super gas
super gas
A tad North of Indy
Probably the right side mount...Have him sit in the car, running with it in gear, CAREFULLY with a floor jack, put a small amount of upward pressure (1/2 inch or so) on the right side of the oil pan. This will take the pressure off the right frame mount. If the vibration goes away the mount is bad. It would be very unusual for the left side to go (trans side) but the same test applys. While on the oil pan, be carefull not to crush the oil filter.
Rick
Blown71X V2.0 under construction
71 Cuda 383 4-SPD (maybe for sale)
2010 Challenger B5 Classic
