Big block oil pump o-ring sizes? #984224
05/01/11 08:42 PM
05/01/11 08:42 PM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
I use a standard volume Melling oil pump with an Indy cover. Does anyone know the exact size of the small and large o-ring for the cover? What about the size for the 3rd o-ring that is on the oil pump housing snout? I'd like to replace all 3 while it is apart.
Re: Big block oil pump o-ring sizes? [Re: ProSport] #984225
05/01/11 08:59 PM
05/01/11 08:59 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
when i needed them, i just went to the hardware store. mancini has them too.
Re: Big block oil pump o-ring sizes? [Re: rickraw] #984226
05/01/11 09:02 PM
05/01/11 09:02 PM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
I can compare them at a hardware store, just thought it might be easier to know a number or size, since they tend to have different thicknesses and widths.
