Fuel pumps - mechanical vs. electric #984180
05/01/11 07:37 PM
05/01/11 07:37 PM
70duster340 Offline OP
I'm sure this has been asked (and debated) here before, but here goes anyway.
What are the advantages and disadvantages to each one? I currently run a Carter street pump, but am open to any advice any of you may have.
TIA!!!
Re: Fuel pumps - mechanical vs. electric [Re: 70duster340] #984181
05/01/11 08:18 PM
05/01/11 08:18 PM
Nobody???
Re: Fuel pumps - mechanical vs. electric [Re: 70duster340] #984182
05/01/11 08:58 PM
05/01/11 08:58 PM
IN
ahy Offline
ahy  Offline
IN
An electric mounted near the tank will pressurize the fuel system in the hot engine compartment and reduce the possibility of vapor lock... which is more of a problem with current gas than it was in the 70's. Electric is commonly available in higher output vs conventional mechanical. Downsides of electric are noise, cost, complexity.
Re: Fuel pumps - mechanical vs. electric [Re: ahy] #984183
05/01/11 09:22 PM
05/01/11 09:22 PM
Central NC
gch Online content
gch  Online Content
Central NC
Your average street car doesent NEED an elec fuel pump.Many mild bracket cars will run fine on a mech pump also.
If you run a smallish (factory)fuel line on a hopped up muscle car an elec pump may keep you out of starvation at higher rpms.
Any nitrous car should run an elec pump (or two).
Re: Fuel pumps - mechanical vs. electric [Re: 70duster340] #984184
05/01/11 11:13 PM
05/01/11 11:13 PM
fire away there is no quota here . As said electric: bad is the noise (need to insulate it)/long wiring to it. Good is it combats vapor lock & would prob let you run a return line for that prob also and gives alot of GPH (w a large line). If you can flow enough w a mechanical that'd b the way to go for simplicity & some of em flow alot. I used a stock parts house low po "airtex" w 5/16" lines on a circle burner SB 360 (9-1) CR 2bbl (class rules) w no starvation issues at 6300 RPM at WOT though I went to a 3/8 line and drilled out/added 3/8" nipples in the in/out barrels on the airtex just to make sure that I wasn't getting starved though I confirmed that w a psi reading & there was no change so the b 4 setup was adequate. Mech is adequate in most cases & much better to deal w/setup
Re: Fuel pumps - mechanical vs. electric [Re: RapidRobert] #984185
05/02/11 11:52 PM
05/02/11 11:52 PM
Thanks for the replies so far. I was asking because I was curious if maybe it freed up some horsepower, and also was maybe a bit more dependable than the mechanical pumps. Not that I have experienced any issues with my Carter pump, but I am just in search of the best setup.
Re: Fuel pumps - mechanical vs. electric [Re: 70duster340] #984186
05/03/11 03:18 AM
05/03/11 03:18 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I always run an electric pump on my hotrods. I just use a block-off plate where the stock fuel pump goes and use just electric. I like it for keeping vapor lock down and for filling the carb bowls as soon as the key is turned on. And it works good if you like to race your car now and then. Ron
Re: Fuel pumps - mechanical vs. electric [Re: 70duster340] #984187
05/03/11 08:09 AM
05/03/11 08:09 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
both will work, depends on your fuel needs. You really don't need and electric unit until you are in the mid-11's.
Coming soon!!!!
Re: Fuel pumps - mechanical vs. electric [Re: Mr.Yuck] #984188
05/03/11 12:58 PM
05/03/11 12:58 PM
Well, I would prefer to avoid the noise, so if there is no real improvement over a mechanical pump, I will stay with what I have.
Re: Fuel pumps - mechanical vs. electric [Re: 383man] #984189
05/03/11 06:02 PM
05/03/11 06:02 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Same here, I will make mine return (instead of dead head) and buy a quieter pump next time...or just make my exhaust louder
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Fuel pumps - mechanical vs. electric [Re: GoodysGotaCuda] #984190
05/04/11 09:06 AM
05/04/11 09:06 AM
Palmyra, NY
63stabamatic Offline
Palmyra, NY
I echo all the comments. One thing to keep in mind is in a crash an electric fuel pump may continue to run and make an explosive situation. That always bothered me, even if was run by the ignition switch and you couldn't get to it, so I got a Ron Francis CR-92 crash sensor that will open an electrical connection to the fuel pump in the event of a crash.
Re: Fuel pumps - mechanical vs. electric [Re: 63stabamatic] #984191
05/04/11 05:08 PM
05/04/11 05:08 PM
IL . usa
cjs69mope Offline
cjs69mope  Offline
IL . usa
You could also use a oil pressure switch to ground the fuel pump relay so the pump turns off when the motor stalls .
I think holley has a diagram for this .
1969 Dodge Charger 1969 Dodge Superbee
