Engine Lubrication #983822
05/01/11 10:12 AM
05/01/11 10:12 AM
Mashpee,MA
mopar360 Offline OP
Can't start my lawn mower
mopar360  Offline OP
Mashpee,MA
Hey everyone im rebuilding my 360 Magnum engine and i was wondering what type of oil(s) i should use when putting then engine back together.
Thanks,
Ethan
All throttle...No bottle! 1979 Chrysler 300 (360) 1984 Chrysler 5th Avenue (318)
Re: Engine Lubrication [Re: mopar360] #983823
05/01/11 10:25 AM
05/01/11 10:25 AM
Several good ways to go. Brad Penn breakin oil is good and Joe Gibbs racing oil & this 5 minute read may interest you. "breakin secrets" at www.mototuneusa.com
Re: Engine Lubrication [Re: mopar360] #983824
05/01/11 11:19 AM
05/01/11 11:19 AM
NoVa
E
ebodyseast Offline
ebodyseast  Offline
E
NoVa
This time of year you can use SAE 30 (straight) weight - remember it doesn't flow at 30' and below - Spring/Summer/Fall rebuilds only...
Re: Engine Lubrication [Re: ebodyseast] #983825
05/01/11 01:02 PM
05/01/11 01:02 PM
Kansas
Menzaero Offline
Menzaero  Offline
Kansas
I have used Joe Gibbs BR break in oil. It' not cheap but its loaded with zinc for our flat tappet engines. You will probably have several hundred or even a few thousand dollars in your build so do cheap out on the oil.
Re: Engine Lubrication [Re: Menzaero] #983826
05/01/11 03:02 PM
05/01/11 03:02 PM
Mashpee,MA
mopar360 Offline OP
mopar360  Offline OP
Mashpee,MA
I ordered the parts i need this morning it came to $960. Where would i be able to find Joe Gibbs BR oil?
