Excessive Amperage? Holley Pump #983810
05/01/11 10:02 AM
05/01/11 10:02 AM
Queens, N. Y.
FASTBACK340 Offline OP
Queens, N. Y.
I just restored my car & when assembling I ran auxiliary wiring for my trunk release, third brake light, & electric fuel pump. All wiring is 14G with soldered and shrink wrapped connections. I've killed two 30A fuel pump relays in less than 2 years. Pump is a new Holley blue. Tank is sumped with a pre-filter before & one after the pump. Should I go 40A, or is my pump suspect? Any advice is appreciated.
Thanks!
`68 Barracuda 340-S
Re: Excessive Amperage? Holley Pump [Re: FASTBACK340] #983811
05/01/11 10:24 AM
05/01/11 10:24 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Thanks!
Get rid of the "pre filter", It's causing problems, I promise you. What size line do you have feeding the pump?
Re: Excessive Amperage? Holley Pump [Re: FASTBACK340] #983812
05/01/11 10:38 AM
05/01/11 10:38 AM
Should I go 40A,
I believe so & seperately is 14 ga enough though that is not causing the prob w the relay
Re: Excessive Amperage? Holley Pump [Re: Challenger 1] #983813
05/01/11 11:07 AM
05/01/11 11:07 AM
Queens, N. Y.
Queens, N. Y.
I'm using -8 feed & supply.
Interesting about the pre-filter. Quite a few people recommended it to, ironically... SAVE my pump! Looks like a simple thing to try. I thought it might be causing a restriction, but with the sump, gravity feed, and thick line....and I know the wiring is better than needed...I figured it was overkill already.
Thanks for the input.
`68 Barracuda 340-S
Re: Excessive Amperage? Holley Pump [Re: FASTBACK340] #983814
05/01/11 11:53 AM
05/01/11 11:53 AM
IN
ahy Offline
ahy  Offline
IN
As a diagnostic, pull the connector to the relay away just enough to get a volt meter probe on the terminals. Get everything running and check voltage on the relay pins. The relay control voltage should be 12+ volts. The pump supply voltage should also be 12+ volts.
14 guage for the relay control wires should be more than adequate. 14 guage for the power wires to the relay and pump may be a little light. The voltage test will tell. Also, not all relays are created equal. Try a Bosch.
PS... the pre-filter should be very coarse - 100 micron is the standard - so it gets the big stuff out without creating too much suction.
Re: Excessive Amperage? Holley Pump [Re: FASTBACK340] #983815
05/01/11 09:06 PM
05/01/11 09:06 PM
Cincinnati, Ohio
Cincinnati, Ohio
Your trying to suck the gas uphill, not the best thing. That much line it should be #10. Pump should be down from the feed. In the wheelwell?
Shouldn't be why your blowing fuse though, that's another issue, I beleive.
What's the micron rating of that filter?
Re: Excessive Amperage? Holley Pump [Re: Challenger 1] #983816
05/01/11 11:17 PM
05/01/11 11:17 PM
Queens, N. Y.
Queens, N. Y.
It's actually the right side trunk extension. I have a plate protecting the pump from the tire side.
I'm going to pull out the pre-filter. We'll see what happens.
Thanks for everyone's input!
`68 Barracuda 340-S
Re: Excessive Amperage? Holley Pump [Re: FASTBACK340] #983817
05/01/11 11:21 PM
05/01/11 11:21 PM
Holler what it ends up being
Re: Excessive Amperage? Holley Pump [Re: FASTBACK340] #983818
05/02/11 01:21 AM
05/02/11 01:21 AM
Rome, GA
GTXX Offline
GTXX  Offline
Rome, GA
as someone else posted, 14 gauge is fine for the control wiring for a relay, but it's not big enough for running the pump. I would use at least 12 gauge, 10 ga wouldn't hurt if you're running 20+ feet of wire to hook to power.
Re: Excessive Amperage? Holley Pump [Re: GTXX] #983819
05/02/11 10:47 PM
05/02/11 10:47 PM
Columbus, Ohio
wheelsup68dart Offline
Columbus, Ohio
Check the pump amperage before and after you pull the pre filter. That pump should only pull 3 amps, if you are pulling high amperage then it could be either b4 or aft filter, a pressure regulator malfunctioning, or the pump windings or brushes going bad. See what combination causes the least amp draw and go from there.
Re: Excessive Amperage? Holley Pump [Re: GTXX] #983820
05/02/11 11:49 PM
05/02/11 11:49 PM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
Agreed!! I always run 10 gauge for the supply on an elec. pump, 8 gauge wouldn't hurt either, 14 gauge is way too small.
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
Re: Excessive Amperage? Holley Pump [Re: wheelsup68dart] #983821
05/03/11 03:13 AM
05/03/11 03:13 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Like the man says check the pump amperage draw before you condem anything else and go from there. If it draws to much then unhook the lines and check it again with just the pump free wheeling as it should draw real low amps free wheeling. I only run 3/8 line with the Holley red pump and I use a pre filter and one at the carb and have never had any problems. 14 gauge is all I ever use for Holley pumps that draw less the 10 amps as thats more then heavy enough for a draw under 10 amps. Good luck , Ron
