Re: 47RH overdrive unit bolt onto 46RH of same year?
[Re: 360view]
#983748
05/01/11 11:20 AM
05/01/11 11:20 AM
Posts: 21,487 It's a dry heat
gtx6970
It's a dry heat
my guess is , Yes it will bolt on. BUT, I've never tired to either.
But typically 47RH trans are considerably just heavier/better built internally.
I';ve never looked at it from a comparison angle so this is all nothing more than a guess on my part.. But,,,,'I think' the OD sprag is a heavier duty unit, more clutches, and the shaft lube passages may be drilled larger to accomidate said changes.
And If I remember right the main / output shaft on the 47 series OD units are larger than the 46 series OD units . Thus requiring a larger driveshaft
[Re: fshd4it]
#983750
05/01/11 09:03 PM
05/01/11 09:03 PM
Posts: 75,089 A Banana Republic near you.
JohnRR
A year or so back I repaired a '98 46re 4wd that had lost lube and basically welded the O/D unit solid. Replaced the bad parts (int. shaft incl.) with stuff from a diesel trans, ('97 IIRC, was all I could find used locally). Other than needing a different piston spacer ring, it went together without a hitch.
That is all you would need to do , other than the different clutch count , 47 has more clutches , it'll bolt right on and hold more mower . just make sure you follow the manual on how to check the required spacer needed or you'll smoke the OD clutches
