EVAP test port location??
#983721
05/01/11 07:26 AM
05/01/11 07:26 AM
Posts: 1,420 Pittsfield, Mass.
Russ_Davis
Pittsfield, Mass.
My friend has a smoker. I need to know where the test port is located. Its and 05 Ram with a 5.7 Hemi. A pic would be great. Thanks
Re: EVAP test port location??
[Re: moparsquid]
#983724
05/01/11 02:56 PM
05/01/11 02:56 PM
Posts: 2,886 US of A
A38s!
US of A
Strange. My 06 5.7 CA-spec doesn't show a check valve port on the em label. They used to have a neon green tag, screw cap and were illustrated on the diagram.
What codes are you throwing?
WANTED: Your 71-78 Late B-body sedan parts! Police or Civilian.
[Re: Russ_Davis]
#983726
05/01/11 04:32 PM
05/01/11 04:32 PM
A38s!
US of A
(no service port)
Install the #8404-ADP service adaptor into the filter line (adjoined to the cannister 1-2' in front the the tank).
Connect the Air supply hose from the EELD to the service port (if equipped) or to the #8404-ADP adapter. Press the remote button to activate AIR flow.
Probably just the gas cap or you may want to check for a TSB.
