904 u-joint #983373
04/30/11 09:45 PM
04/30/11 09:45 PM
Kentucky
dfsmopars Offline OP
Kentucky
Is there a difference in how u-joints over the years fit up on the tranny yolk? Is there a difference in the dimension from groove to groove?
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring
‘14 Big Horn, Quad Cab, 4x4, 1500
Re: 904 u-joint [Re: dfsmopars] #983374
04/30/11 09:53 PM
04/30/11 09:53 PM
Park Forest, IL
slantzilla Online content
slantzilla  Online Content
Park Forest, IL
904 should have the 7260 U-joint. Not sure they ever made a 7290 yoke.
Re: 904 u-joint [Re: slantzilla] #983375
04/30/11 10:07 PM
04/30/11 10:07 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
A 7290 yoke is available for the 904's thru the aftermarket, I don't think the factory ever made one unless it would be for a truck/van application, but I don't think they ever did.
Re: 904 u-joint [Re: dartman366] #983376
04/30/11 11:01 PM
04/30/11 11:01 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Never saw one if they did. course 904's in trucks or vans were virtually a non existent thing around here
Re: 904 u-joint [Re: dfsmopars] #983377
04/30/11 11:46 PM
04/30/11 11:46 PM
Kentucky
Kentucky
My son and I tried to assemble a front yoke tonight that he bought at Indy at the swap meet. It fits in the 904 but we cannot press the caps together far enough to get both clips in. I measured the space between the ears on the yoke and it is 1.125" It does not look damaged by looking or measuring. It just seems that there needs to be about another 1/16" between the ears. I have assembled plenty of u-joints and never had this problem so I am wondering if there was a change in that dimension for different years.
Re: 904 u-joint [Re: dfsmopars] #983378
05/01/11 12:15 AM
05/01/11 12:15 AM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Make sure one of the bearings didn't fall out of place. All it takes is one loose one to make the cap dimension too big ---- been there, done that!
Re: 904 u-joint [Re: Neil] #983379
05/01/11 12:18 AM
05/01/11 12:18 AM
Kentucky
Kentucky
Yep, I've done that too before but no this time.
Re: 904 u-joint [Re: dfsmopars] #983380
05/01/11 08:13 AM
05/01/11 08:13 AM
Upper Midwest
Upper Midwest
Well something went wrong because as far as I know thatis the only joint that came on them. I have seen them semi air lock making them bit of a job to squeeze down to get the clips on and taking a couple of good raps with a hammer to get them to seat. Too much grease in the cups will definitely stop the seating possess till some is taken out.
