2002 dodge dakota R/T not firing #983245
04/30/11 03:09 PM
04/30/11 03:09 PM
TN
1973 Mopar Offline OP
TN
My 2002 dodge dakota R/T v8 5.9 is getting fire to the coil but no fire is coming out. Does anyone know why any help would be greatly appreciated.?
Re: 2002 dodge dakota R/T not firing [Re: 1973 Mopar] #983246
04/30/11 03:15 PM
04/30/11 03:15 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
When my 96 did that I was the sensor in the distributor.
Re: 2002 dodge dakota R/T not firing [Re: stumpy] #983247
04/30/11 03:46 PM
04/30/11 03:46 PM
TN
TN
Thanks stumpy! I will check that now! Will that cause the coil not to fire?_
Re: 2002 dodge dakota R/T not firing [Re: 1973 Mopar] #983248
04/30/11 04:11 PM
04/30/11 04:11 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Yes it send the signal to the coil. First time it happened it drove me crazy tracing it down. Mine was a 3.9 v6 so I'm not sure it's the same but it's worth cehcking. It's listed as a distributro pick up. Can you do the key dance on a 02 and get the codes?
Re: 2002 dodge dakota R/T not firing [Re: stumpy] #983249
04/30/11 04:31 PM
04/30/11 04:31 PM
TN
TN
Yes and I also have an OB2 computer. Thanks for your input. We just went to Advanced auto parts and picked up a coil pick up. I will let you know if it fixes it.
Re: 2002 dodge dakota R/T not firing [Re: 1973 Mopar] #983250
04/30/11 05:23 PM
04/30/11 05:23 PM
TN
TN
That part didn't work when I check my codes it flashes 12 times do you know what that means. Thanks
Re: 2002 dodge dakota R/T not firing [Re: 1973 Mopar] #983251
04/30/11 05:36 PM
04/30/11 05:36 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
What does your OBD2 reader say?
Re: 2002 dodge dakota R/T not firing [Re: stumpy] #983252
04/30/11 05:50 PM
04/30/11 05:50 PM
TN
TN
It said random misfires and an o2 sensor but it was probably caused from whatever happened to the truck. It started to lose power and miss real bad before it died and never started back up.
Re: 2002 dodge dakota R/T not firing [Re: 1973 Mopar] #983253
04/30/11 06:34 PM
04/30/11 06:34 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
No real data here, but have heard that magnum coils like to weaken and crap.
Re: 2002 dodge dakota R/T not firing [Re: buildanother] #983254
04/30/11 07:33 PM
04/30/11 07:33 PM
TN
TN
Thanks buildanother!
Re: 2002 dodge dakota R/T not firing [Re: 1973 Mopar] #983255
04/30/11 09:38 PM
04/30/11 09:38 PM
Michigan Troll
blk00rt Offline
blk00rt  Offline
Michigan Troll
did you try the sensor that is on the bell housing I think its the crank position sensor..that will keep it from firing.
though you should start with the basics, when was your last tune up? is your cap and rotor still good? Do you have a msd system?
Rob Dunn
1976 Dart Sport 360
2000 dakota RT 408 with 150 nitrous
2013 Dodge Ram 1500 Hemi
2009 Jeep Patriot
