Could this be.... the 3rd transmission failure!?!
#982922
04/29/11 11:01 PM
04/29/11 11:01 PM
Posts: 492 Kansas
BEINGmeISaCRIME
Kansas
Here goes... We have a 1998 durango, 5.2, 4wd, 44re transmission. The original transmission went out at about 150,000 miles. Went to advanced and ordered a new reman transmission. $1600 later we got the transmission and hooked back up to the engine. Filled it up partway and started it up and put into neutral, found out the case was cracked so we took it out and sent it back. New transmission showed up (january) and now I believe this one is starting to go.
When shifted into reverse or manual low, the durango will shudder, drop to about 300 rpm then it'll die, about 75% of the time. If you shift into drive or 2, everything operates like normal. At one point in time the o2 sensor failed throwing a code and got that fixed but the problem still exists.
The transmission fluid level is fine, not burnt smelling or discolored (still cherry red). From what I've been told, the problem is within the reverse/low clutch pack. Could that be the cause of this? The transmission is still under warranty but I doubt I will send it back in for a new one seeing as this is the second one I've received.
Re: Could this be.... the 3rd transmission failure!?!
[Re: BEINGmeISaCRIME]
#982924
04/29/11 11:08 PM
04/29/11 11:08 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
sorry but the units that Advance and the other chain parts stores sell are not very good units. You would be better off finding a good local repair facility to handle the job.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
#982927
04/30/11 12:37 AM
04/30/11 12:37 AM
Posts: 30,493 Florida STAYcation
dOc …
The village idiot's idiot
Florida STAYcation
Yeah, did that between the swap from the 1st to 2nd transmission
16 huN for a bone-stock OEM-type trans you have to put in ..... is a rip.
#982928
04/30/11 02:15 AM
04/30/11 02:15 AM
Posts: 3,699 Newport, Mi
Evil Spirit
Newport, Mi
First, if you shift into low or reverse, and the car is not moving, does the problem occur then? If so, it is a torque converter issue, probably in the lockup area. At idle, in any gear, and the car not moving, the input shaft should not be turning, and torque converter slippage should let the engine idle with minimal drag. Having the trans scanned may show up that the computer is trying to lock the converter up for some reason. Second, if the problem occurs as you are moving in manual low or reverse, then it probably is either the low/reverse BAND (there is no low/reverse CLUTCH) and/or the over running clutch (rear sprag) is failing. Both would have to occur for the problem to happen in both rev and man low. Even if the low/rev band was slipping the rear sprag should hold for a clean first gear. A better description of what is happening is needed.
Free advice and worth every penny... Factory trained Slinky rewinder.........
[Re: Magnum]
#982934
04/30/11 02:54 PM
04/30/11 02:54 PM
Posts: 492 Kansas
BEINGmeISaCRIME
Kansas
Was the cooler flow tested???
and was it flushed out after the transmission failure/before installation.
Yep
