Could this be.... the 3rd transmission failure!?! #982922
04/29/11 11:01 PM
04/29/11 11:01 PM
Kansas
BEINGmeISaCRIME Offline OP
Kansas
Here goes... We have a 1998 durango, 5.2, 4wd, 44re transmission. The original transmission went out at about 150,000 miles. Went to advanced and ordered a new reman transmission. $1600 later we got the transmission and hooked back up to the engine. Filled it up partway and started it up and put into neutral, found out the case was cracked so we took it out and sent it back. New transmission showed up (january) and now I believe this one is starting to go.
When shifted into reverse or manual low, the durango will shudder, drop to about 300 rpm then it'll die, about 75% of the time. If you shift into drive or 2, everything operates like normal. At one point in time the o2 sensor failed throwing a code and got that fixed but the problem still exists.
The transmission fluid level is fine, not burnt smelling or discolored (still cherry red). From what I've been told, the problem is within the reverse/low clutch pack. Could that be the cause of this? The transmission is still under warranty but I doubt I will send it back in for a new one seeing as this is the second one I've received.
Re: Could this be.... the 3rd transmission failure!?! [Re: BEINGmeISaCRIME] #982923
04/29/11 11:06 PM
04/29/11 11:06 PM
IN
ahy Offline
ahy  Offline
IN
If its still under warranty, I'd send it back and get another. No reason not to that I know of.
Re: Could this be.... the 3rd transmission failure!?! [Re: BEINGmeISaCRIME] #982924
04/29/11 11:08 PM
04/29/11 11:08 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
sorry but the units that Advance and the other chain parts stores sell are not very good units.
You would be better off finding a good local repair facility to handle the job.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Could this be.... the 3rd transmission failure!?! [Re: BEINGmeISaCRIME] #982925
04/29/11 11:46 PM
04/29/11 11:46 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Was the cooler flow tested???
Re: Could this be.... the 3rd transmission failure!?! [Re: NITROUSN] #982926
04/29/11 11:48 PM
04/29/11 11:48 PM
Kansas
Kansas
Yeah, did that between the swap from the 1st to 2nd transmission
Re: Could this be.... the 3rd transmission failure!?! [Re: BEINGmeISaCRIME] #982927
04/30/11 12:37 AM
04/30/11 12:37 AM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
16 huN for a bone-stock OEM-type trans you have to put in ..... is a rip.
Re: Could this be.... the 3rd transmission failure!?! [Re: BEINGmeISaCRIME] #982928
04/30/11 02:15 AM
04/30/11 02:15 AM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
First, if you shift into low or reverse, and the car is not moving, does the problem occur then? If so, it is a torque converter issue, probably in the lockup area. At idle, in any gear, and the car not moving, the input shaft should not be turning, and torque converter slippage should let the engine idle with minimal drag. Having the trans scanned may show up that the computer is trying to lock the converter up for some reason. Second, if the problem occurs as you are moving in manual low or reverse, then it probably is either the low/reverse BAND (there is no low/reverse CLUTCH) and/or the over running clutch (rear sprag) is failing. Both would have to occur for the problem to happen in both rev and man low. Even if the low/rev band was slipping the rear sprag should hold for a clean first gear. A better description of what is happening is needed.
Free advice and worth every penny...
Factory trained Slinky rewinder.........
Re: Could this be.... the 3rd transmission failure!?! [Re: BEINGmeISaCRIME] #982929
04/30/11 02:33 AM
04/30/11 02:33 AM
md
W
wicked Offline
wicked  Offline
W
md
I have not had good luck with advance auto trans, and they try to skate the warranty due to instalation error
Re: Could this be.... the 3rd transmission failure!?! [Re: wicked] #982930
04/30/11 03:05 AM
04/30/11 03:05 AM
Mission BC
10sec440 Offline
10sec440  Offline
Mission BC
I agree it sounds like a convertor issue.
Re: Could this be.... the 3rd transmission failure!?! [Re: 10sec440] #982931
04/30/11 10:16 AM
04/30/11 10:16 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Re: Could this be.... the 3rd transmission failure!?! [Re: NITROUSN] #982932
04/30/11 01:26 PM
04/30/11 01:26 PM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
and was it flushed out after the transmission failure/before installation.
Re: Could this be.... the 3rd transmission failure!?! [Re: Evil Spirit] #982933
04/30/11 02:52 PM
04/30/11 02:52 PM
Kansas
Kansas
In first or reverse it will shift slowly in gear and will kill the engine before you can get moving. If you give it some gas while it's shifting you can get it to move with some ferocious jerking internally.
Re: Could this be.... the 3rd transmission failure!?! [Re: Magnum] #982934
04/30/11 02:54 PM
04/30/11 02:54 PM
Kansas
Kansas
Yep
Re: Could this be.... the 3rd transmission failure!?! [Re: BEINGmeISaCRIME] #982935
04/30/11 03:02 PM
04/30/11 03:02 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
what went bad on the original trans, just burnt out, did you do fluid changes?
Re: Could this be.... the 3rd transmission failure!?! [Re: ademon] #982936
04/30/11 04:30 PM
04/30/11 04:30 PM
Kansas
Kansas
The original one had originally started slipping around 140,000 and made it to 150,000 slipping on a 1-2 shift. Then it received some abuse in winter time getting stuck on the road. When it finally gave out it was all burnt up. Last fluid change on the original was around 100,000.
Also: Today put it on ramps and unplugged the transmission electrical connectors that run up to the computer. While it was in limp-in mode, it experienced the same problems as before. That should eliminate the computer as being the problem, leading it back to some sort of engine/transmission type of deal.
Re: Could this be.... the 3rd transmission failure!?! [Re: BEINGmeISaCRIME] #982937
04/30/11 08:26 PM
04/30/11 08:26 PM
MINNESOTA
BRONZEBEE Offline
BRONZEBEE  Offline
MINNESOTA
Plugged cooler,loop the cooler lines together and see if it helps.Big problem with transmission coolers in the factory radiators.I never use a old cooler with a rebuilt transmission,bypass original radiator and run an stand alone cooler.
