Re: 77 Cordoba,How many parts will work on 72 Rally Charger
[Re: High Impact]
#982813
04/30/11 11:12 AM
04/30/11 11:12 AM
Posts: 2,886 US of A
A38s!
US of A
Don't toss some stuff because it won't fit a 72. I stash 360/4 parts these days.
WANTED: Your 71-78 Late B-body sedan parts! Police or Civilian.
[Re: 451Mopar]
#982817
04/30/11 07:08 PM
04/30/11 07:08 PM
Posts: 1,562 Manistee, Michigan.
High Impact
Manistee, Michigan.
Its a running driving car that needs some attention but could be driven as is. He wants to trade me a 454 thats been sitting on a shelf in my shop for it. I probably should........its just that the motor takes up alot less room than ANOTHER car. I thought the bucket seats were the same but Im not sure. My 72 car was missing the correct seats. Would the disk brakes work on my 1967 Sport Fury? Or, My 68 Charger? Everything else I have already has disks. How about the rear sway bar? I know it has the fancy chrome road wheels for that era car and there complete and shine really nice yet.........Thats a bonus! Just curious what you guys thought
[Re: kilroy]
#982820
05/01/11 01:31 PM
05/01/11 01:31 PM
Posts: 6,095 Valencia, España
NachoRT74
Valencia, España
false!
inner fenders are totally diff, radiator core support, frame rails are diff too. NOTHING of the front clip unibody will interchange correctly, K member and suspension won't interchange.
Actually even the firewall COULD fit, the 77 bulkhead opening is diff.
between 72 and 73 Chargers, the floor pans fit up to trunk, dutchman panel, roof, glasses, cowl, Hoods, trunk lid ALTHOUGH cilinder will need to keep matching the correct lid year because that changed too between 72 and 73. Rear valance will fit BUT bumper guards cut outs changes. Front valance fits but you can tell diff on inner areas and brackets to frame rails. Fenders fits BUT inside you can tell areas won't match, ( will find BIG diff unmatched areas with radiator core support ) and won't be able to fit correct wheel op molds.
Wiring will be a perfect match between a 72 and a 73 with just some wires turned around at bulkhead easy to match, but thing are diff with 74s and EVEN MORE DIFF with laters.
Doors won't, quarters won't, quarter glass won't...
Dash frame will interchange as complete assembly with a 77 BUT dunno if clusters can be interchanged, I don't think so. Glove box and ashtray parts will.
etc...
[Re: kilroy]
#982823
05/01/11 11:38 PM
05/01/11 11:38 PM
NachoRT74
Valencia, España
which kind ? the full glass kind or the one mounted on pot metal frame ?
Not saying won't fit, since bolting locations are the same BUT if you see a 73/74 glass they are bigger. 71/72s are a little bit smaller so adjusting on C area could be some "tight" into the opening area once aligned with doors. Also teh vertical seal and molding is shorter on 71/72s than 73/74s
[Re: NachoRT74]
#982824
05/03/11 01:27 AM
05/03/11 01:27 AM
Posts: 540 murfreesboro, TN
Qbird
murfreesboro, TN
73/74 charger roof is actually 71/72 Satellite disguised by trim.
[Re: Qbird]
#982825
05/03/11 03:28 AM
05/03/11 03:28 AM
NachoRT74
Valencia, España
actually roof itself is the same between Plymouth and Dodges on those years ( 71/74 2 doors B bodies ) since the quarter window opening shape is not on roof, its on quarter panel
however the CHARGER glass, its diff between 71/72 and 73/74 ( as stated not saying won't fit somehow )... 71/72 Plymouth, yes is the same than 73/74 Charger, so does the opening shape
