do you oil the back side of a bearing shell? #982535
04/29/11 01:55 PM
04/29/11 01:55 PM
Guitar Jones Offline OP
I never have but I've seen others that do so what's your opnion?
Re: do you oil the back side of a bearing shell? [Re: Guitar Jones] #982536
04/29/11 01:59 PM
04/29/11 01:59 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Why would one , it doesn't move , or at least it shouldn't ?
Re: do you oil the back side of a bearing shell? [Re: JohnRR] #982537
04/29/11 02:14 PM
04/29/11 02:14 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
Nope,I wipe mine clean and install them dry,then lube the bearing surface.
I want nothing between the back of the bearing and it's mating surface so it can transfer heat out as well as possible.
Keith
Re: do you oil the back side of a bearing shell? [Re: Dunnuck Racing] #982538
04/29/11 02:20 PM
04/29/11 02:20 PM
Winnipeg ,Mb. CA.
chryco Offline
chryco  Offline
Winnipeg ,Mb. CA.
Keith
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
Re: do you oil the back side of a bearing shell? [Re: Guitar Jones] #982539
04/29/11 02:22 PM
04/29/11 02:22 PM
Minn
SportF Offline
SportF  Offline
Minn
I do as that engine might sit around a while before firing and I don't want any rust in there. I always make sure all interior parts are coated with oil to prevent rust. A number of years ago I built an engine for my street rod and after sitting for a couple of years in the chassis it wouldn't turn over very well and I ended up taking it apart to clean it up. I usually bag it and seal with a dryer now, but everything still gets oiled. Engines are a great place for condensation, even inside an insulated garage.
Re: do you oil the back side of a bearing shell? [Re: Guitar Jones] #982540
04/29/11 02:33 PM
04/29/11 02:33 PM
MOPAR HEADQUARTERS IN ALDEN NY
hemigod426 Offline
hemigod426  Offline
i use one drop of 3-1 oil on back of each bearing spread out with finger,so mains/rods bearings seat perfect in saddles while torque is applied
MOPAR OR NO CAR
Re: do you oil the back side of a bearing shell? [Re: hemigod426] #982541
04/29/11 04:32 PM
04/29/11 04:32 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
No
Re: do you oil the back side of a bearing shell? [Re: B G Racing] #982542
04/29/11 05:18 PM
04/29/11 05:18 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
No
Rich H.
Esse Quam Videri
Re: do you oil the back side of a bearing shell? [Re: ZIPPY] #982543
04/29/11 05:37 PM
04/29/11 05:37 PM
Az
Crizila Offline
Crizila  Offline
Az
Yes - but I'm not sure I'm right.
Fastest 300
Re: do you oil the back side of a bearing shell? [Re: ZIPPY] #982544
04/29/11 05:38 PM
04/29/11 05:38 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
About 40 some years ago a engine builder told me not to touch the back side of the bearing and bearing surface and bearing seat area with your fingers after wiping down the areas with a clean cloth.I don't even use my finger to spread out the oil on the journals. Been doing that on every build since. Can't see why you would oil the back side.
Re: do you oil the back side of a bearing shell? [Re: Crizila] #982545
04/29/11 05:43 PM
04/29/11 05:43 PM
Interesting comments. The way I looked at it is that with oil on the backside there may be a tendancy for a little extra crush on the bearing. If or when that oil eventually vacates the saddle it may leave the bearing shell just a tad looser and since the crush is the only thing that keeps that bearing from spinning it doesn't seem like a good idea to me.
Re: do you oil the back side of a bearing shell? [Re: rowin4] #982546
04/29/11 05:44 PM
04/29/11 05:44 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
No, leave them dry.
Re: do you oil the back side of a bearing shell? [Re: rowin4] #982547
04/29/11 05:46 PM
04/29/11 05:46 PM
Florida STAYcation
dOc ! Online penguin-006
The village idiot's idiot
dOc !  Online Penguin-006
Florida STAYcation
Oil ? ... I have always cleaned-'em-off real-good with some type of solvent or gas.
Re: do you oil the back side of a bearing shell? [Re: Dunnuck Racing] #982548
04/29/11 05:46 PM
04/29/11 05:46 PM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
Keith
I assemble mine dry on the backside.....................
but as for heat transfer, it seems like, to me, a layer of oil would actually tranfer heat better. More molecules of matter providing surface contact. But I think too much about stuff anyways.
Re: do you oil the back side of a bearing shell? [Re: rowin4] #982549
04/29/11 05:46 PM
04/29/11 05:46 PM
Walton's Mountain, Pa
Steve1118 Offline
Steve1118  Offline
I go even further....it's probably overkill, but I dip the bearing shell in lacquer thinner, then use a rag dipped in lacquer thinner to wipe the saddle clean before installing the shell. I've done it that way for forty years.
So....absolutely not. No oil or substance of any kind between the shell and the saddle.
"Old age and treachery trumps youth and enthusiasm, every time!"
East Central Director / Chrysler Power Magazine
www.reasbeckracing.webs.com
Re: do you oil the back side of a bearing shell? [Re: Guitar Jones] #982550
04/29/11 05:47 PM
04/29/11 05:47 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
No.
Crush is set by the actual ID of the bearing bore period. The bore is measured dry, and bearings are installed dry ( backside). Anything that is not the original parent bore, shouldnt be there, including dust, schars of metals, lint,. paper towel fragments etc.It also always a good idea to take a dressing stone and lightly champher all the outside edges of the bearing bores, as often ( especially newly reconditioned rods) they can slightly mushroom there and actually hold the bearing up slightly.
RIP Monte Smith
Re: do you oil the back side of a bearing shell? [Re: CompWedgeEngines] #982551
04/29/11 05:58 PM
04/29/11 05:58 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Leave em dry but I clean the bearing surfaces with ATF, not for lubrication but for corrosion resistance as I would with any newly machined surface exposed to atmosphere and moisture. I also swab all the cylinder and lifter bores with ATF until every bit of grit/dust/dirt is out of them and they wipe perfectly clean before assembly. ATF on a white cloth shows eveen the slightest bit of dirt plus it's so thin it cleans all the nooks and crannies.
Probably old school as all get out but that's my gig and I ain't blowed one up yet!! grin:
WIZE
In Car:
Re: do you oil the back side of a bearing shell? [Re: Streetwize] #982552
04/29/11 06:22 PM
04/29/11 06:22 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Yep. I didn't till Garlits told me too lol. He said it gets back there anyway
Re: do you oil the back side of a bearing shell? [Re: FastmOp] #982553
04/29/11 07:04 PM
04/29/11 07:04 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
I allways put them in as dry and as clean as possible. Thinking that, it would give more resistance to spinning the bearing in a low oil psi situation.
Last month I was having some fitness issues with some mains on a RB and had the crank in and out several times.
No matter how clean I got the back side of the bearing, and its saddle. The oil found its way back there. They were clean when I put them in, but they had lube between the bearing and saddle after everytime I took them out.
Re: do you oil the back side of a bearing shell? [Re: Guitar Jones] #982554
04/29/11 08:04 PM
04/29/11 08:04 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
dry. if u build an engine & it's going to sit 4 a while, just prime it, oil will get where it supposed 2. seeya.
