i ran a set of 29x15.5x15 on 12 rims on the street 14 months with no tubes
ran about 18#psi max 20psi
they are soft and wear fast for street driveing,but do wrinkle up and handle med to high HP levels on the street.i would drop them to around 12psi IIRC
went to the M/T sportsman SR radials,they have been on the truck 2 yrs and still look new(no burn outs)
SRs is much better on the wet road,the pros like to hydro plane at a much lower speed.
the M/T sportsman is same as a pro but a longer lasting rubber compound for street use,they like to hydroplane also.
the SRs have been at some good speed in the wet and no hint of hrydoplaning so far.
this is all on my shortbed truck lowerd and tubbed.
