How are the Pheonix 28.5x10.50 slicks? #982368
04/29/11 01:34 AM
04/29/11 01:34 AM
Redding,CA USA
440charger500 Offline OP
Redding,CA USA
Thinking about getting a set of these for the charger, tell me what you think of these slicks.
Re: How are the Pheonix 28.5x10.50 slicks? [Re: 440charger500] #982369
04/29/11 08:05 AM
04/29/11 08:05 AM
ohio
dart70 Offline
dart70  Offline
ohio
Awesome tire, I have that size on my small block Dart and have been 10.24 @128, 1.38 sixty foot, very consistant.
Re: How are the Pheonix 28.5x10.50 slicks? [Re: 440charger500] #982370
04/29/11 01:28 PM
04/29/11 01:28 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
Phoenix tires are awesome!! Hook well and last a long time.They will hook when the cords are showing.
Nautilus Racing-
Re: How are the Pheonix 28.5x10.50 slicks? [Re: Chris2581] #982371
04/29/11 04:06 PM
04/29/11 04:06 PM
Redding,CA USA
Redding,CA USA
Sounds good I just hope the 13" section width will fit under my charger without rubbing. I would be the only one at the track with pheonix slicks just havent seen any of them around here.
Re: How are the Pheonix 28.5x10.50 slicks? [Re: 440charger500] #982372
04/29/11 06:29 PM
04/29/11 06:29 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I used to run them on a 4.5 back space 10 inch rim on my gtx cleared just fine. Later when i went 29.5 X 11.5 had to make some room on the wheel well same rims.
Re: How are the Pheonix 28.5x10.50 slicks? [Re: Dodgem] #982373
04/29/11 10:39 PM
04/29/11 10:39 PM
Redding,CA USA
Redding,CA USA
that sounds good my rims are 4.5" backspace.
Re: How are the Pheonix 28.5x10.50 slicks? [Re: 440charger500] #982374
04/30/11 12:23 AM
04/30/11 12:23 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
My car did not sit too low 3800 lb SS springs with an extra leaf.
MP ones seemed a little soft to me??
Re: How are the Pheonix 28.5x10.50 slicks? [Re: Dodgem] #982375
04/30/11 12:41 AM
04/30/11 12:41 AM
Redding,CA USA
Redding,CA USA
I've got new espo heavy duty springs, so I wont have to worry about old sagged leafs anymore.
Re: How are the Pheonix 28.5x10.50 slicks? [Re: 440charger500] #982376
04/30/11 10:31 AM
04/30/11 10:31 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Yea I never liked a car that sat low. last years springs were Cal trac monos' with 1" extra lift I thought was perfect. We are setting my new coil overs to that same height! Using 31 X 14 this year.
was running mid 11's when I ran the 28.5 X 10.5's true street strip back then. And yes the Pheonix hook till cords show so you have to watch the depth holes.
