Door panel vapor barrier adhesive
#98224
08/01/08 01:35 PM
08/01/08 01:35 PM
Posts: 2,640 Port Reading, NJ
roadrunner7070
Port Reading, NJ
What do you guys use to attach the vapor barrier to the inside door panel? Something that can easily be removed and then pasted again.
Re: Door panel vapor barrier adhesive
[Re: 68jim]
#98233
08/02/08 12:50 AM
08/02/08 12:50 AM
Posts: 9,065 Milwaukee, WI
In_The_Pink
Milwaukee, WI
This is what I used, works great. 3M #08578 Runs about $12-15 for a box.
Easy to remove and won't dry out, unlike tape adhesive.
