Re: Advise please on stock 440 head rebuild [Re: Dodgem] #982234
04/30/11 03:45 AM
04/30/11 03:45 AM
md
W
wicked Offline
wicked  Offline
W
md
Wow Thanks for all the replies! I am on a tight budget. I want to keep this stock and numbers matching. If the original valves are not bad, should I just have them ground or should I replace them? If I do replace the valves I will be using Elgin Industries steel replacement valves. Will it make a difference because I'm having hardened exhaust seats installed?
And just what is "bowl blending"???
Well if you break the head off a 40 year old exhaust valve that has been heat cycled a 100,000 times and is weakened, stressed and plum worn out you will see what a few dollars saved you!!!!
I have and it ain't pretty. Course I got to build a brand new motor heads and all!
Solid advice, they have been known to get brittle, alot of risk vs. cost
Re: Advise please on stock 440 head rebuild [Re: wicked] #982235
04/30/11 10:22 AM
04/30/11 10:22 AM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
Do you care to tell us the price to have your heads redone? I know its very EASY to tally up $600-700 in new parts and labor. Thats why some on this board recommend the areo heads with the plan to have them examined and corrected.
Keep old mopars alive.
Re: Advise please on stock 440 head rebuild [Re: 2boltmain] #982236
04/30/11 11:16 AM
04/30/11 11:16 AM
Western US
Furious440 Offline OP
Western US
Well, the machine shop quoted $400 for labor.
I purchased all my own parts which has ran about $400 as well for valves, springs, retainers, locks, seals, rockers with shafts, freeze plugs and studs. That does not include all of the engine gaskets. I am resealing the engine.
I do not want to go with aftermarket or any other heads as the goal is to keep everything original.
So far, no one been able to answer my question about modifying the head for better valve cover gasket sealing?
Re: Advise please on stock 440 head rebuild [Re: Furious440] #982237
04/30/11 11:46 AM
04/30/11 11:46 AM
Suffolk,VA
I
ireland383 Offline
ireland383  Offline
I
Suffolk,VA
I used the Felpro cork gaskets and no problems with mine. Are you using stock valve covers? The key is to not over tighten them.
Re: Advise please on stock 440 head rebuild [Re: ireland383] #982238
04/30/11 12:21 PM
04/30/11 12:21 PM
Western US
Western US
Yes. The valve covers and everything else is all stock. I will use an inch-pound torque wrench when it comes time to put on the valve covers.
Re: Advise please on stock 440 head rebuild [Re: Furious440] #982239
04/30/11 12:36 PM
04/30/11 12:36 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
These help
http://www.summitracing.com/parts/PRO-66003/
there is lotso different types
http://www.summitracing.com/search/?keyword=valve+cover+hold+downs&page=3
I like these gaskets
http://www.summitracing.com/search/Part-...er/?Ns=Rank|Asc
and i like to liberally coat both sides with Right Stuff stick to valve cover then install snug lightly leave over night then tighten.
I don't think 71 heads had hardened seats
