PCV Valve or not for a turbo? #982009
04/28/11 04:32 PM
04/28/11 04:32 PM
MD
ADakotaRTGuy Offline OP
MD
Trying to figure out if you need it or not? Planned on having a line from each valve cover to a catch can with a breather on top of it, does it need anything else?
Re: PCV Valve or not for a turbo? [Re: ADakotaRTGuy] #982010
04/29/11 12:18 PM
04/29/11 12:18 PM
Houston, Texas
TheOtherDodge Offline
Houston, Texas
That is the way to do it..
Re: PCV Valve or not for a turbo? [Re: TheOtherDodge] #982011
04/29/11 02:11 PM
04/29/11 02:11 PM
MD
MD
So no PCV valve and its good to go?
Re: PCV Valve or not for a turbo? [Re: ADakotaRTGuy] #982012
04/29/11 03:13 PM
04/29/11 03:13 PM
HEMPSTEAD TX
CUUDAK Offline
CUUDAK  Offline
HEMPSTEAD TX
I will most likely use a backfire proof valve in the dp and use it for crankcase evac. like my drag car had. Just make sure your valvecovers have the baffle in them so the oil won't get sucked out thru the exhaust.
SRT8 CHARGER "Four door bore" <img src="/ubbthreads/images/graemlins/smile.gif" alt="" />
Re: PCV Valve or not for a turbo? [Re: CUUDAK] #982013
04/29/11 03:21 PM
04/29/11 03:21 PM
MD
MD
Got a link to what I could use?
Re: PCV Valve or not for a turbo? [Re: ADakotaRTGuy] #982014
04/29/11 06:55 PM
04/29/11 06:55 PM
HEMPSTEAD TX
CUUDAK Offline
CUUDAK  Offline
HEMPSTEAD TX
http://compare.ebay.com/like/40020638430...4=263602_325002
These weld into the dp where it turns to go to the exhaust. You may need just one. One is about half this price!
Re: PCV Valve or not for a turbo? [Re: ADakotaRTGuy] #982015
04/30/11 12:03 PM
04/30/11 12:03 PM
Houston, Texas
Houston, Texas
Your original plan is how most do it...
