NSS Wedge Combinations
#981875
04/28/11 12:32 PM
04/28/11 12:32 PM
Posts: 5,160 Texas
dannysbee
Texas
You guys that are running NSS what is your engine package,weight,gears,stall and performance? Please note if you are using stock block. Thanks
Getting old just means you were smarter than some and luckier than others.
Re: NSS Wedge Combinations
[Re: dannysbee]
#981876
04/28/11 02:02 PM
04/28/11 02:02 PM
Posts: 680 COLUMBUS, OH
Whompin_Wedge
COLUMBUS, OH
557 kb block b1 originals motor done by koffel indy crossram damon kuhn carbs 800 eddys 9inch ATI stalls about 5000 4.56 dana 3600lb car on 29.5X10.5 best so far 9.57 at 141 with a 1.28 60 Casey
[Re: dannysbee]
#981877
04/28/11 02:20 PM
04/28/11 02:20 PM
Posts: 204 Indiana
MFR426
Indiana
64 Belvedere (3400Lbs) Low budget build! 440 original block (.060 over) with steel caps over stock main caps; original iron crank: 12.5/1 J&E pistons; eagle rods; 610 Comp (roller) Cam; 1963 Maxwedge intake; 2 Edelbrock 750 carbs by George Lawrence; Repop iron Maxwedge heads; Machine work by Beachy Kokomo, IN. Coan 8" converter with low gear A&A Torqueflite 8 3/4 with Moser spool and 4:56 gears Goodyear 10.5 X 30 tires Best 10.69 at 126 Good Luck! with whatever combo you do!
[Re: MFR426]
#981878
04/28/11 02:26 PM
04/28/11 02:26 PM
Posts: 5,160 Texas
dannysbee
Texas
looks good MFR426 what does she weigh with driver?
[Re: sunroofgtx]
#981881
04/28/11 04:00 PM
04/28/11 04:00 PM
Posts: 2,379 MD
Kevins493
MD
493 ci based on stock 440 block (.030 over, 4.15 crank)...manley h beams, ross flattops- 12.5:1ish compression. Indy 440-1 heads that have been ported, not sure on the flow. .689 roller with 268/272 duration at .050. Indy 440-25 intake with 2 750s set up by Bob George. 727 with 2.77 first and converter flashing at 5200. 4.10 dana with 29.5-10.5 tires. Only had it out once this year, and on the second full pass it went 10.04 at 132 in a 25 mph headwind. Will have it out this weekend. Same combo with about 12:1 comp went 10.31 at 132 with the stock '63 cross ram on it. 3370lb with driver.
[Re: Kevins493]
#981882
04/28/11 05:53 PM
04/28/11 05:53 PM
Posts: 449 Wisconsin
sjs64polara
Wisconsin
Did you change gears, stall, or cam when you replaced the cross ram and went to the Indy How much higher are you shifting. I called Indy and asked some questions but I got the cold shoulder. Any input would really help
[Re: sjs64polara]
#981883
04/28/11 07:50 PM
04/28/11 07:50 PM
Posts: 2,379 MD
Kevins493
MD
Changed nothing but the intake. Well...cam is different from the 10.31 pass but i used that cam early last year with the cross ram and it ran about half a tenth faster for the conditions, but we hurt the motor before we could get decent air. It went 10.44 with that cam in a 30 mph headwind at the same track in similar conditions to the 10.04 pass. Also, the nose on my car is drooped and we had to get creative to make the front carb fit. Was shifting at 6500 with the cross ram. Went to 6800 with no change on the indy, but we changed something else for the next pass so i left the shift point at 68 so as not to corrupt any information we got..
[Re: d330]
#981886
04/29/11 09:11 AM
04/29/11 09:11 AM
Posts: 9,849 MI, usa
dvw
MI, usa
540 m/p iron block m/p cross-ram 770 holleys 3450# 4.88 gear clutch pedal..no stall [Email]9.13@148[/Email]
Is your car the Hemi stick? More about your combo.
[Re: dvw]
#981887
04/29/11 09:21 AM
04/29/11 09:21 AM
dvw
MI, usa
Old combo.63 Polara,498,-1 Indy unported,stock cross ram,stock 750 carters,.680 roller,13-1,3450lb,J converter,4.10. Best runs 10 teens at 130-132mph. New combo. 64 Belvedere,572,mega block,-1 MCH ported,T&D 1.7,.285/292@.800 roller,belt drive,aluminum rod,15-1 W/flat top,Indy cross ram. How fast? Who knows. I've been working on it forever. Doug
[Re: dvw]
#981888
04/29/11 10:08 AM
04/29/11 10:08 AM
Posts: 5,160 Texas
dannysbee
Texas
DVW that would be my guess as he is running Holleys. No holleys with wedges right? Which car is it the Coronet or the Fury? Dah I just looked at your handle yours is the Dodge.
[Re: dannysbee]
#981889
04/29/11 10:19 AM
04/29/11 10:19 AM
Posts: 5,160 Texas
dannysbee
Texas
Whompin_Wedge how hard was it to fit the indy intake on the B1 original heads?
[Re: dannysbee]
#981890
04/30/11 12:37 AM
04/30/11 12:37 AM
Whompin_Wedge
COLUMBUS, OH
got adapters plates from best machine.. just a little milling from koffel no biggie..
Casey
[Re: d330]
#981892
04/30/11 05:32 PM
04/30/11 05:32 PM
dvw
MI, usa
both cars are hemi 4 speeds.. i have the black 330.. stage 5 aluminum heads. bullet roller cam. jerico trans.
the plymouth has the same combo. but, has a g-force trans.. over the winter he changed to a sheet metal crossram and removed #450 pounds.. that car should dip well into the 8's this year..
How's the drivetrain life with the stick at the Dodges weight? I'd love to run a stick but the mantainance scares me. What type of trans,axle,and clutch? Doug
