Re: how much power 727
[Re: 440Jim]
#981808
04/28/11 05:38 PM
04/28/11 05:38 PM
Posts: 75,066 U.S.S.A.
JohnRR
U.S.S.A.
IMO, the 727 design will handle much more torque than you will NA. However, your particular build and parts condition is not known. If you put a power adder on it, I would recommend a better valve body at the minimum.
What are you referring to in your post?
I didn't connect the detent cable
What he said , if that means you did not connect the throttle valve linkage , what people refer to as the kickdown linkage , which is the linkage from the carb to the trans you will smoke the front clutch in short order.
With a 125 shot I would hope it has better than the cheapy rebuild kit clutches and you definitely need a shift kit that increases the line pressure.
[Re: JohnRR]
#981809
04/28/11 08:59 PM
04/28/11 08:59 PM
Posts: 16,928 NC
440Jim
NC
