Re: Compression test results
[Re: GregY]
#981635
04/27/11 10:34 PM
04/27/11 10:34 PM
RapidRobert
To me the #'s dont look good (too much variation) plus the white smoke from #7. Did it smoke/use oil like that b 4 it overheated? I would suspect the rings and maybe gasket issue (the white sm). I'd pump it up to 15 lbs w the Stant rad pump & let it sit. Holler what it ends up being
[Re: RapidRobert]
#981636
04/27/11 10:43 PM
04/27/11 10:43 PM
Posts: 1,200 Rochester, New York
GregY
Rochester, New York
Thanks Robert.
No, it didn't use oil or smoke like that before.
Can you tell me what the radiator pressure test will tell me compared to a leak down test? I have the stuff to do a leak down test, I would need to buy the Stant kit.
Greg
[Re: GregY]
#981637
04/27/11 10:53 PM
04/27/11 10:53 PM
RapidRobert
The adv of the Stant pump is it'll tell you if coolant is leaking in (or out) as opposed to a leakdown which'll tell you what % of cyl psi is leaking out which maybe a combo of rings/valves/gasket. Not sure I'd buy a new one but I got one at a sale cheap & it does come in handy once in a while esp for checking cooling system integrity b 4 adding coolant & w you the white smoke worries me
[Re: RapidRobert]
#981639
04/27/11 11:01 PM
04/27/11 11:01 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
On a fresh battery recheck the low cylinders again. If low again, squirt some wd 40 in the hole and run the numbers again. IMO 30 psi is significant. And the cylinders are adjoined. well let me put it this way, If ity was my engine, I would be disappointed in those numbers, and would be looking for a root cause. But I like things to be just so..
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
