Speedometer pinion hole #981519
04/27/11 05:22 PM
04/27/11 05:22 PM
Georgia
K
kimber Offline OP
kimber  Offline OP
K
Georgia
What's the size of the hole on the transmission where the speedometer pinion goes. The transmission I have is leaking from it, and I'll just like to plug it up.
Re: Speedometer pinion hole [Re: kimber] #981520
04/27/11 07:03 PM
04/27/11 07:03 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Why not simply REPLACE the O ring?
Re: Speedometer pinion hole [Re: Kern Dog] #981521
04/27/11 11:56 PM
04/27/11 11:56 PM
Georgia
K
kimber Offline OP
kimber  Offline OP
K
Georgia
Well, I've done that, but it still leaks. I thought I'll just plug it since there's no speed-o cable going to it anyway.
Re: Speedometer pinion hole [Re: kimber] #981522
04/28/11 12:08 AM
04/28/11 12:08 AM
Winlock, Wa
fshd4it Offline
fshd4it  Offline
Winlock, Wa
According to Carl Munroe's 727 book, a 1-49/64" freeze plug fits.
In order to know what you want, you'll probably have to find out what you don't want.
Re: Speedometer pinion hole [Re: fshd4it] #981523
04/28/11 12:11 AM
04/28/11 12:11 AM
Florida STAYcation
dOc ! Online penguin-006
The village idiot's idiot
dOc !  Online Penguin-006
Florida STAYcation
x2 on the freeze-plug fix.
Re: Speedometer pinion hole [Re: dOc !] #981524
04/28/11 04:10 AM
04/28/11 04:10 AM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
Also consider looking in a wrecking yard. SOME 4wd Dodge trucks had a blank plug in that hole, since the speedo actually connects to the transfer case.
Re: Speedometer pinion hole [Re: Kern Dog] #981525
04/28/11 09:15 AM
04/28/11 09:15 AM
scratchnfotraction Offline
did you change the small seal inside the speedo housing on the gear pinion shaft along with the big o-ring?
there are 2 seals for it,if you clock the housing so the gear is not spinning,it would help stop it from wearing and leaking.
the freeze plug will work fine also.
a cheap rubber core plug would be eazy and fast to remove if you went back to a working speedo.
Re: Speedometer pinion hole [Re: scratchnfotraction] #981526
04/28/11 12:53 PM
04/28/11 12:53 PM
Georgia
K
kimber Offline OP
kimber  Offline OP
K
Georgia
Thanks for the info. I appreciate your help.
Re: Speedometer pinion hole [Re: fshd4it] #981527
04/29/11 11:30 PM
04/29/11 11:30 PM
Georgia
K
kimber Offline OP
kimber  Offline OP
K
Georgia
Thanks to everybody for your input. I went to advance auto parts and they didn't have a freeze plug to fit. Seeing how 1-49/64 is 1/64 bigger than 1-3/4 I got one of the rubber freeze plug that measured 1-3/4 to 1-7/8 for $3.99. It went right in, tighten the nut and walla problem fixed.
