Any tips for compressing end link bushings to install? #981430
04/27/11 01:34 PM
04/27/11 01:34 PM
Tenn.
jrwoodjoe Offline OP
Tenn.
Trying to install the rear sway bar on my Challenger and I'm having trouble compressing the end link bushings enough to allow me to get the nut started. I have put the bushings in the freezer hoping they would compress enough but they don't. Any suggestions?
Thanks, Joe
65 Barracuda
70 Challenger
Re: Any tips for compressing end link bushings to install? [Re: jrwoodjoe] #981431
04/27/11 02:09 PM
04/27/11 02:09 PM
Under My Car
Mopar_Country Offline
Under My Car
Do you have a valve spring compressor like this one? Might work if you can get it on there. Just a thought.
Re: Any tips for compressing end link bushings to insta [Re: Mopar_Country] #981432
04/27/11 05:34 PM
04/27/11 05:34 PM
Tenn.
Tenn.
I don't have one but may have access to one. That's a possibility. Thanks for the tip.
Re: Any tips for compressing end link bushings to insta [Re: jrwoodjoe] #981433
04/27/11 07:51 PM
04/27/11 07:51 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Are the bushings rubber or poly ?
Re: Any tips for compressing end link bushings to insta [Re: JohnRR] #981434
04/27/11 08:21 PM
04/27/11 08:21 PM
Tenn.
Tenn.
Hey John,
They are rubber. Before I put them in the freezer they had more "give". Putting them in the deep freeze made them shrink but now they don't "give". Trying to install them on the spring bracket, I can get them all on and once the bottom washer goes on I no longer have room to get the nut started. I had clamp that I use to do wood work and tried to use that but the end link kept wobbling and I never could get a strong enough clamp down on it.
Re: Any tips for compressing end link bushings to insta [Re: jrwoodjoe] #981435
04/27/11 08:53 PM
04/27/11 08:53 PM
IN
ahy Offline
ahy  Offline
IN
From memory, its a 3/8" bolt that clamps them. How about a little longer bolt?
Re: Any tips for compressing end link bushings to insta [Re: jrwoodjoe] #981436
04/27/11 09:21 PM
04/27/11 09:21 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
I've used big (Jumbo) channellocks & I've used a wood clamp..
Re: Any tips for compressing end link bushings to insta [Re: 1_WILD_RT] #981437
04/27/11 10:01 PM
04/27/11 10:01 PM
Ohio
john55 Offline
john55  Offline
Ohio
I've also used a small bottle jack if your working on the floor, put the jack under the bolt and push it a little then you should be able to get the nut started, I have a hoist and a pit jack to put pressure on the bolt
The Plymouth Win You Over Beat Goes On
Re: Any tips for compressing end link bushings to insta [Re: ahy] #981438
04/28/11 01:36 PM
04/28/11 01:36 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
This , if it is just a bolt I would just get a little loger bolt , or the next size up and trim as necessary then later on it you must have the more correct looking bolt try swapping the shorter one in.
Re: Any tips for compressing end link bushings to insta [Re: JohnRR] #981439
04/28/11 02:00 PM
04/28/11 02:00 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
This , if it is just a bolt I would just get a little loger bolt , or the next size up and trim as necessary then later on it you must have the more correct looking bolt try swapping the shorter one in. [/quote
But it's not just a bolt, the threaded area is smaller than the bolt shank so it's special... It really is an easy task to do it right why make it difficult...
Re: Any tips for compressing end link bushings to insta [Re: 1_WILD_RT] #981440
04/28/11 03:14 PM
04/28/11 03:14 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Never dealt with these so I don't know about the special bolt .
Re: Any tips for compressing end link bushings to insta [Re: JohnRR] #981441
04/28/11 05:40 PM
04/28/11 05:40 PM
Tenn.
Tenn.
Factory link looks like this...
65 Barracuda
70 Challenger
Re: Any tips for compressing end link bushings to insta [Re: jrwoodjoe] #981442
04/28/11 05:54 PM
04/28/11 05:54 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Nevermind then, didn't realize they used that on the rear also.
I put that type link bolt on the front of my Dart, don't remember having any problem putting it together.Maybe trim a little off one of the bushings ?
Re: Any tips for compressing end link bushings to insta [Re: JohnRR] #981443
04/29/11 11:21 AM
04/29/11 11:21 AM
Tenn.
Tenn.
Thanks for the suggestions guys, I'll try some and see what I can come up with.
Joe
65 Barracuda
70 Challenger
