1970 GTX #981321
04/27/11 03:47 AM
04/27/11 03:47 AM
New York
buck0123 Offline OP
buck0123  Offline OP
New York
One heater core line has a metal tube with a tee, one line goes to water pump other line goes to bottom of engine. anyone know what this is for.
Re: 1970 GTX [Re: buck0123] #981322
04/28/11 06:48 AM
04/28/11 06:48 AM
New York
buck0123 Offline OP
buck0123  Offline OP
New York
anyone?
Re: 1970 GTX [Re: buck0123] #981323
04/28/11 06:53 PM
04/28/11 06:53 PM
Where on the eng?
Re: 1970 GTX [Re: buck0123] #981324
04/28/11 06:57 PM
04/28/11 06:57 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
certainly doesn't sound stock to me!
Re: 1970 GTX [Re: mikemee1331] #981325
04/28/11 08:47 PM
04/28/11 08:47 PM
KY
b5a12bee Offline
b5a12bee  Offline
KY
Sounds like someone put a tee in there so you can flush the system.Probably so you can hook up a water hose to the tee.
Re: 1970 GTX [Re: b5a12bee] #981326
04/30/11 02:14 AM
04/30/11 02:14 AM
New York
buck0123 Offline OP
buck0123  Offline OP
New York
There is a metal tube with a tee in one of the heater core lines. Both lines go to the water pump and the line that has the tee in it also goes to the bottom of the engine on the pass. side, hard to see i cant tell if it goes to one of the freeze plug holes or what.
