C body parts #980727
04/25/11 11:44 PM
04/25/11 11:44 PM
Ontario.Canada
can.al Offline OP
can.al  Offline OP
Ontario.Canada
..a friend called and said he scored a '72 full size Mopar with a 400 in it.(Newport?)
is that early 400 anything special?
i seem to remember something about '72 C body disc brakes and also the rear axle.
i'm going over tomorrow to take a look before he crushes it!
Re: C body parts [Re: can.al] #980728
04/26/11 12:23 AM
04/26/11 12:23 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
400 will be a good core for a stock stroke or stroker build even if it isn't the so-called 230 block.
If the car is a late build 72 it might have the 73 style spindles that take the 1 piece unicast rotors which are more desirable for C-body disc brake swaps. Even if it has the 2 piece rotors they are still good to put discs on a drum C-body.
Trans will be good too. Not sure when they went to the 9.25 rear but if it has an 8.75 it will likely be a 2.76 but could be a SG so check it to be sure.
Kevin
