Re: Opinions on cylinder head selection
[Re: GregY]
#980644
04/25/11 09:20 PM
04/25/11 09:20 PM
Posts: 4,799 ILL
MLR426
ILL
Do a set of 906 heads, the 346 head is terrible. You will still have to have those Indy heads prepped with a better valve job,runner,valve pocket and port clean up. Then you can think about cam, compression, intake, carb etc. The 71 charger is a heavy car, your going to need more gear also too get that car moving. This project can quickly turn into a money monger, cylinder heads are an important part of making the power you need to run hard, add everything up before jumping in head first. Your budget build can quickly get out of hand to support the time you expect to run.
logan426
[Re: GregY]
#980645
04/25/11 09:43 PM
04/25/11 09:43 PM
RapidRobert
Muscle Motors' Steve Dulcich (whose forgotten more info than I know) states that the later heads 452's etc are far easier for the home porter to improve on as opposed to the earlier 906/915 though 452's would need to b thoroughly crack checked & I would get the MP templates & port em (lot of gain/not too much work). Might go to MM archives & read his articles. Been a few reported probs w Indy's stuff but prob no more than the norm (& maybe even less) than any rebuilder as you (most of the time) only get the bad news on stuff here. I ran a set (SB's) of their rebuilt ones & no issues. Iron heads need alot replaced/reworked to get em right but as you said alum ones are $$$ plus need to b checked over after you buy them. Myself in your case w a mild 440 I'd do a bare bones rebuild on your 346's & save for a good set later. dont remem if 346's had hardened seats as they were close to the changeover on that & we know how Ma was on supposed published changeover years
[Re: RapidRobert]
#980646
04/25/11 09:51 PM
04/25/11 09:51 PM
Posts: 843 Suffolk,VA
ireland383
Suffolk,VA
My 346's had hardened seats. There was a test on iron heads 906,346,452 and they all flowed pretty much the same. I had my 346's done and to be honest for not much more I got the Stealths. They flow a he!! of a lot better than the irons.
[Re: JohnRR]
#980650
04/26/11 08:30 PM
04/26/11 08:30 PM
Posts: 1,210 Rochester, New York
GregY
Rochester, New York
The 346 has the same basic intake port as the 452 , flat floor with no short turn.
Greg you are in Rochester NY, contact Dwayne Porter, member fast68plymouth 802 951 1955
Thanks John, I will look into that.
