ProCharger big block Mopars #980495
04/25/11 04:30 PM
04/25/11 04:30 PM
Houston, TX
rick55 Offline OP
rick55  Offline OP
Houston, TX
My son asked me to post these videos of a couple of big block Mopars they recently built for customers.
First is a 540 cube F-3 built for Joe Capps.
http://www.stevemorrisengines.com/racing-videos/engine-dyno-videos/joe-capps-540-f3r-bbchry
The next one is a 526 cube F-3 built for Brett Ward.
http://www.stevemorrisengines.com/racing-videos/engine-dyno-videos/jeff-wards-526ci-f3r-bbchry
Re: ProCharger big block Mopars [Re: rick55] #980496
04/26/11 03:54 PM
04/26/11 03:54 PM
Canada
Kam*Kuda Offline
Kam*Kuda  Offline
Canada
Love that... urn down the boost for a 1500 hp street tune
1970 Barracuda Convertible
1968 Satellite Street Strip car
1654.5 Mustang
1955 Land Rover
Re: ProCharger big block Mopars [Re: Kam*Kuda] #980497
05/04/11 05:44 PM
05/04/11 05:44 PM
Grand Rapids, MI
K
killerswinger Offline
K
Grand Rapids, MI
We will be building a big cube Big Block Chrysler with twin F2 ProChargers here in another month or so. I will be sure to post up the video or have my dad do it for me.
I think it's going to make the two motors in this thread look a bit silly. It's going to be sweet
Re: ProCharger big block Mopars [Re: rick55] #980498
05/08/11 01:59 AM
05/08/11 01:59 AM
Staten Island N.Y.
Dap Offline
Dap  Offline
Staten Island N.Y.
Is that the Holley Dominator EFI they were running on Brett Ward`s 526?
PRH446
10.084 @ 135.21 mph N/A through chambered mufflers,3300lbs. Stock stroke wedge
Re: ProCharger big block Mopars [Re: Dap] #980499
05/11/11 12:31 PM
05/11/11 12:31 PM
Houston, TX
rick55 Offline OP
rick55  Offline OP
Houston, TX
Yes, that is a Holley Dominator EFI. My son says they are "sweet".
Re: ProCharger big block Mopars [Re: rick55] #980500
05/13/11 10:01 PM
05/13/11 10:01 PM
QLD Australia
Keith Black® Offline
QLD Australia
hmmmmm.. does anyone know:
1. if there is a model of the F2 ProCharger with helical cut gears?
2. with a ProCharger engine (let's say it's setup for max boost 19-20psi @7000rpm) -when operating at low crankshaft speeds, say <2,500 rpm, would the intake manifold be in boost/vacuum sort of pressure zone or do they always be in boost ?
Darren Beale
Keith Black Racing Engines®
Re: ProCharger big block Mopars [Re: Keith Black®] #980501
05/22/11 01:47 AM
05/22/11 01:47 AM
Temperance, MI
P
prochargedhemi Offline
P
Temperance, MI
The "blow off valve" if you will, bleeds off boost. It works in conjunction with throttle blade position so i would think at that low of rpm you would be in vacuum but you may also have 1-5 psi by that time. fyi, ive seen upwards of 40 psi with an f-2 on a sbf overspinning the blower by about 10k
