Re: Cost of 46RE Transmission rebuild?
[Re: cdp]
#980394
04/25/11 04:06 PM
04/25/11 04:06 PM
Posts: 3,903 Oregon
hooziewhatsit
Why does it cost that much? Because there are a lot of parts. Then they have to cover any future warranty work, etc. Here's a guide to reassemble one with a ton of pictures. http://www.jeepforum.com/forum/f13/46re-tutorial-911009/
[Re: hooziewhatsit]
#980395
04/25/11 04:15 PM
04/25/11 04:15 PM
Posts: 1,074 detroit, mi
POS Dakota
detroit, mi
OK, can someone explain to me why it cost 2k for a transmission rebuild in my 97-360/2wd truck?
Is there somewhere I can buy a rebuilt transmission outright for about $1000?
If you want to save money, pull it yourself and bring it in. But doing it that way, it can't be scanned...
No you wont get a rebuilt 46re for anywhere near 100 bucks. it will likely cost over 2000 bucks anywhere. Sometimes over 3000.
Too bad you're not closer. I have one with maybe 200 miles on it that I am replacing with a 727. I just wont ship it.
[Re: cdp]
#980400
04/25/11 07:34 PM
04/25/11 07:34 PM
Posts: 377 Michigan Troll
blk00rt
Michigan Troll
damn when mine was done, I pulled it and took it to a trans place, it was under 750 to have that done, they had to replace the planetary gears set and clutches.
Rob Dunn 1976 Dart Sport 360 2000 dakota RT 408 with 150 nitrous 2013 Dodge Ram 1500 Hemi 2009 Jeep Patriot
[Re: cdp]
#980401
04/25/11 08:13 PM
04/25/11 08:13 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
I realize there are allot of parts/sub assemblies, but from what I've looked at, a whole rebuild kit can be had for less than $200.
I guess if you consider warranty, then that could drive up the costs.
now add the cost of a bushing kit,band,gov sol and transducer,the od bearing and plate,the filter,torque converter all these are something a normal overhaul will need if is done correctly now add some ones labor and the cost of fluid and let the shop make a little profit to cover the warranty you get.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: slantzilla]
#980404
04/25/11 11:25 PM
04/25/11 11:25 PM
Posts: 18,157 Mass
DAYCLONA
Mass
OH NOOOOOOOOOO!!!!!!!!!!!!!!! Shops are never supposed to make profit on anything. (At least from what I gather reading threads on moparts)
There!, fixed your quote ........I gladly paid the shop the $2200 they wanted to rebuild the piss poor designed/engineered POS transmission in my 99 Ram 4X4,....because it would have went to the scrapper before I would have wasted my time under it,....I can rebuild anything, and have for decades, but I draw the line working on piss poor designed crap,....the 94-up Dodge truck line drivelines are, and have been a joke for decades,....sad
[Re: DAYCLONA]
#980405
04/26/11 01:52 AM
04/26/11 01:52 AM
Posts: 5,221 Branson, Mo.
joedust451
super gas
super gas
Branson, Mo.
I'll drink to that
[Re: fox]
#980408
04/26/11 12:56 PM
04/26/11 12:56 PM
Posts: 75,089 A Banana Republic near you.
JohnRR
The 46-47-48 series doge autos are not a junk design. They were poorly assembled and set up with much too low pressures. Get the clearances right and pressures right and they hold a lot of torque. The faster chevy duramaxes are using this trans instead of the allison!!! The Cummins does not hurt them if set up right. They are a basic 727 auto from the 60's with OD on it.
What he said .
[Re: fox]
#980409
04/26/11 04:47 PM
04/26/11 04:47 PM
Posts: 492 Kansas
BEINGmeISaCRIME
Kansas
Hmm... I need to get my hands on this info on modification. Does the same apply to newer 45 and 545 rfe transmissions? A friends ram 2006 that is, transmission gave out at 60,000 miles
