Stripping bad paint from door panels #980256
04/25/11 02:23 PM
04/25/11 02:23 PM
Snohomish County, WA
Spidey Offline OP
Spidey  Offline OP
Hello,
My daughter and I just bought a 1970 Challenger. Although it is in great shape, someone rattle-canned the door panels and other interior parts with cheap paint. It is flaking in some areas, dripping in others, and looks pretty bad. Is there a way to strip this paint off? What would you suggest?
Thanks!
Re: Stripping bad paint from door panels [Re: Spidey] #980257
04/25/11 06:24 PM
04/25/11 06:24 PM
Georgetown Ontario Canada
anlauto Offline
anlauto  Offline
Pressure washer at your local coin wash...
CHECK OUT MY NEW WEB SITE !
Re: Stripping bad paint from door panels [Re: Spidey] #980258
04/25/11 06:31 PM
04/25/11 06:31 PM
St. Louis, Mo
3
318 Stroker Offline
318 Stroker  Offline
St. Louis, Mo
Lacguer thinner also works. I've used it on Challenger panels. Works well and doesn't harm the plastic...
Re: Stripping bad paint from door panels [Re: 318 Stroker] #980259
04/26/11 10:26 AM
04/26/11 10:26 AM
cataclysm80 Offline
cataclysm80  Offline
I've also heard that dot 3 brake fluid would do the trick.
Tav
Re: Stripping bad paint from door panels [Re: cataclysm80] #980260
04/26/11 11:38 AM
04/26/11 11:38 AM
SE Wisconsin, USA
RP's R/T's Offline
RP's R/T's  Offline
SE Wisconsin, USA
I've taken many door panels to the chemical stripper (like you would use for stripping paint and rust from sheetmetal). Works great. Chemical doesn't affect most plastic. Door panels, consoles, inner fender splash shields, etc. My only caution is that most chemical stripping places are used to working with metal so you will need to ask them to be more careful to not get knocked around.
Find a place that specializes in stripping furniture and they are more careful.
I've also had some stripped with soda-blasting.
Re: Stripping bad paint from door panels [Re: RP's R/T's] #980261
04/27/11 01:41 PM
04/27/11 01:41 PM
Spidey Offline OP
Spidey  Offline OP
Awesome. Thanks everyone!
