ECU Wires
#98014
08/01/08 07:14 AM
08/01/08 07:14 AM
This is a followup on the coil getting hot thread. https://board.moparts.org/ubbthreads/show...rue#Post4581423 After dealing with this problem and installing the FBO kit, I realize my wiring has been monkeyed with in the past. Could some of you check your ecu wiring harness and tell me if the black with yellow tracer wire is going to the - side of the coil. Thats what all the wiring diagrams a see show. Mine is going to the + side. Could this have been causing my problem all along? Thanks for your help!
Re: ECU Wires
#98016
08/01/08 09:57 AM
08/01/08 09:57 AM
It seems like the car wouldn't run with the wires hooked up wrong on the coil.
Anyone???
Re: ECU Wires
[Re: Dakota_Don]
#98018
08/01/08 01:09 PM
08/01/08 01:09 PM
actully it can run hooked up backwards.. and will make the coil hot as you stated above..
switch them around
I think you'll find this is incorrect. the cause for running hot, that is.
Re: ECU Wires
#98019
08/01/08 01:31 PM
08/01/08 01:31 PM
Posts: 2,072 Cambridge, Ontario, Canada
CUDAJAS
Anyone???
Yep, mine ran that way. It was always hard to start though. I rewired it, and boy does it fire easy now!
Re: ECU Wires
[Re: CUDAJAS]
#98020
08/04/08 11:00 AM
08/04/08 11:00 AM
This is really strange. My car will not even start with the wire going to the - side. Fires right up with it on the + side though! Blasted wiring!!!!!!
