Side clearence alloy rods, how much? #980096
04/25/11 05:58 AM
04/25/11 05:58 AM
Netherlands
72Challenger Offline OP
Netherlands
Hi guys and galls. I'm currently checking out an 400 -> 500ci halffilled engine with new bme alloy rods in it and seem to have a lot of side play. For an approx 800hp street strip engine with tge rods torqued down how much clearence would you consider either optimal and max? Measured cold of course...
All opinions appreciated!
Thanks!
Re: Side clearence alloy rods, how much? [Re: 72Challenger] #980097
04/25/11 08:38 AM
04/25/11 08:38 AM
ontario canada
mac56 Offline
mac56  Offline
ontario canada
If they are a chev rod they will have a lot of side clearance. I have been running aluminum chev rod on mopar width journal without issue for several years. Strictly track use.
Re: Side clearence alloy rods, how much? [Re: 72Challenger] #980098
04/25/11 09:21 AM
04/25/11 09:21 AM
gregsdart Offline
gregsdart  Offline
You need at least .020, more is just fine.
Re: Side clearence alloy rods, how much? [Re: gregsdart] #980099
04/25/11 12:32 PM
04/25/11 12:32 PM
Netherlands
Netherlands
Thanks so far guys. The minimum is not my concern, it's the maximum this time. Have to take a closer look with a correct feeler gauge but if seems to be more around .06
Re: Side clearence alloy rods, how much? [Re: 72Challenger] #980100
04/25/11 10:08 PM
04/25/11 10:08 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
.06 wont hurt a thing, .02-.03 would be better for the oil that gets flung, but no problem.
Re: Side clearence alloy rods, how much? [Re: dthemi] #980101
04/27/11 05:35 AM
04/27/11 05:35 AM
Netherlands
Netherlands
Thanks guys! Time to close it all up and put it in the car this weekend.
Re: Side clearence alloy rods, how much? [Re: 72Challenger] #980102
04/27/11 02:17 PM
04/27/11 02:17 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
It seems that .030+ is common on the ones that I fool with
Re: Side clearence alloy rods, how much? [Re: dthemi] #980103
04/27/11 08:09 PM
04/27/11 08:09 PM
Charlotte, NC
LSP Offline
LSP  Offline
Charlotte, NC
Can you explain this please?
Re: Side clearence alloy rods, how much? [Re: LSP] #980104
04/27/11 08:17 PM
04/27/11 08:17 PM
Florida STAYcation
dOoC Online penguin-006
The village idiot's idiot
dOoC  Online Penguin-006
Florida STAYcation
I think that you will wind-up with 30 with alum rods when they warm-up.
Re: Side clearence alloy rods, how much? [Re: LSP] #980105
04/27/11 08:23 PM
04/27/11 08:23 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
I think the theory here is the larger the side clearance the more oil will sling off the crank adding to windage drag,
Re: Side clearence alloy rods, how much? [Re: emarine01] #980106
04/27/11 08:44 PM
04/27/11 08:44 PM
Florida STAYcation
Florida STAYcation
NOT a theory ....it beez a fact ! ....some of the PROS run as small as 007 with steel rods.
Re: Side clearence alloy rods, how much? [Re: dOoC] #980107
04/27/11 08:56 PM
04/27/11 08:56 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
I know Doc... I was just covering my ass
Re: Side clearence alloy rods, how much? [Re: dOoC] #980108
04/29/11 07:42 AM
04/29/11 07:42 AM
Charlotte, NC
LSP Offline
LSP  Offline
Charlotte, NC
The oil "slinging" from the rods is metered by rod bearing clearance, .010", .020", .040", or .060" rod side clearance won't change the oil flow one bit.
Who's the "PROS" that run .007" rod side clearance?
Re: Side clearence alloy rods, how much? [Re: LSP] #980109
04/29/11 11:18 AM
04/29/11 11:18 AM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
True to a point... tight side clearance can increase oil pressure compared to loose... A tighter side clearance will slow down the oil loss but its not the main factor.... light weight oil vs heavy weight oil use the same principal... resistance to flow.... with the same input pressure if you narrow the gap the volume will decrease and the pressure will rise. I have seen a 5 psi gain @ hot idle with tight rocker arm side clearance on mopar shaft oiling... .006 vs .012 and a large difference in the volume of oil dumped in the head.
Re: Side clearence alloy rods, how much? [Re: emarine01] #980110
04/29/11 11:52 AM
04/29/11 11:52 AM
Florida STAYcation
Florida STAYcation
This topic is never going to be laid-to-rest .....
Bearing and rod-side clearances ? .... ALL of this is a "leak" in the chain. For someone to say that there is no diff in this RSC "leak" between 10 and 60 ....... is uNsane !
WHO was talking about 007 ? .... WJ. And IIRC ...from that article ... he ran a steel rod motor at 11 all the time.
Re: Side clearence alloy rods, how much? [Re: dOoC] #980111
04/30/11 08:39 AM
04/30/11 08:39 AM
Charlotte, NC
LSP Offline
LSP  Offline
Charlotte, NC
Rod vertical bearing clearance is what meters oil flow, not the side clearance... not today, not tomorrow, not ever.
Don't believe everything you read, WJ does not have any steel rod motors.
Re: Side clearence alloy rods, how much? [Re: LSP] #980112
04/30/11 12:48 PM
04/30/11 12:48 PM
Florida STAYcation
Florida STAYcation
I wish that someone like Barton, Hughes or Koffel would come-on this topic and put this to REST.
But to say that RSC has NOTHING to do with oil-flow is just flat-out wrong. Again ...it is just another "leak" in the oil-supply chain.
Re: Side clearence alloy rods, how much? [Re: dOoC] #980113
04/30/11 01:21 PM
04/30/11 01:21 PM
gregsdart Offline
gregsdart  Offline
Its pretty simple, really. There will be some restriction if you run them tight. But guys run them with far more than what will provide any restriction what so ever. If you have a .003 bearing clearance, then .003 extra(or slightly more) side clearance will give you as much room for the oil to escape as a larger clearance will. With folks running them very loose as with stock width BBC rods on stock width mopar journals, it must be apparent that the increase in oil flow isn't enough for most of us to worry about. It probably will show up on a dyno, but I wouldn't want to spend the time or money figuring out how close i could run them before disaster strikes. It would probably come from bind between rods, not an oiling issue.
Re: Side clearence alloy rods, how much? [Re: gregsdart] #980114
04/30/11 02:11 PM
04/30/11 02:11 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Rod side clearance in the static state would prove too large a gap to retain any oil.... But in a dynamic state the gap moves all over the place changing the direction of oil flow.... the added resistance to flow can slow the loss and raise the pressure... but then again it all sounds good in theory but hard to prove.... @ 8k things are moving and changing kinda fast....
Re: Side clearence alloy rods, how much? [Re: dthemi] #980115
04/30/11 02:28 PM
04/30/11 02:28 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Large rod side clearance is not gonna hurt anything other than as pointed out windage and oil that ends up in suspension. As DT pointed out .060" aint gonna hurt nothing othen and having more oil in suspension in the crankcase.
But hey I am not a Barton what do I know...
