Re: Its a juggling act.....Compression and spark advance.
[Re: JimG]
#980057
04/25/11 01:41 PM
04/25/11 01:41 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
You've got EXACTLY the same engine as mine. Same cubes, same CR (I calculated mine at 10.9:1, but close enough), same cam, aluminum heads (mine are Eddys, you didn't say what yours are). I have a Performer RPM with a 850 VS Holley.
I have no problem at all running 35 degrees total with a quick-ish curve. I have about 12 degrees of vacuum advance and use whatever 93 octane pump gas is handy.
How's your carb tune? Have you checked it with a wideband meter or a 4 gas meter on a chassis dyno? Barring that, how's the spark plug color?
You live in Virgina, we live in California... you have gasoline, we have cow piss..
[Re: Kern Dog]
#980059
04/25/11 02:44 PM
04/25/11 02:44 PM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
If you have good 0.040" quench, thicker head gaskets may make the pinging worse even though the compression is slightly lower. I'm calculating the cranking compression pressure should be about 153psi? which should be ok, but with the hydraulic cam if the lifters are bleeding down it will make the cam seem smaller and raise cylinder pressures. Anyhow, if pulling the heads, I would try to maintain good quench clearance, and take a few cc's out of the cylinder head chambers, unshrouding the valves and polishing the chambers.
[Re: Kern Dog]
#980060
04/25/11 02:44 PM
04/25/11 02:44 PM
Posts: 12,423 Kalispell Mt.
HotRodDave
Kalispell Mt.
Octane is octane no matter where you are. You may have more ethanol (actual 10% vs mabey 10%) but ethanol helps ward off detonation not increase it.
Something else is wrong, like too much vaccume advance, too hot of engine temp, too lean of carb mix... that cam should be more than enough to bleed off any excess compression unless it is advanced too much. I would check over the combo real good before ditching precious compression and possibly quench. What pistons are you running and how far are they above or below the deck?
[Re: Viol8r]
#980064
04/25/11 07:27 PM
04/25/11 07:27 PM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
Spark plugs.... That subject has come up before. I have used the plugs recomended by Edelbrock: RC12YC. I suppose that the "12" is the heat range? A 10 number would make it a colder plug and therefore LESS prone to detonation? Whats the downside to running a colder spark plug? The motor has about 1000 miles on it. I doubt that it would oil foul with properly seated rings.
[Re: Kern Dog]
#980068
04/25/11 07:58 PM
04/25/11 07:58 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Colder plug resists detonation but if you go to cold it will be prone to fouling... The more compression the colder the plug needs to be...
