correct distributor for 69 gtx #980001
04/25/11 12:04 AM
04/25/11 12:04 AM
In.
bjg Offline OP
bjg  Offline OP
In.
Could someone tell me the correct distributor for my 69 gtx 440 4 speed part number name brand and picture would be appreciate. thanks
Re: correct distributor for 69 gtx [Re: bjg] #980002
04/25/11 10:50 AM
04/25/11 10:50 AM
Arizona
az426john Offline
az426john  Offline
Arizona
Here is what I could find.
Tag information:
Mopar 2875772 or replacement unit 2875773
Prestolite IBS-4014B
It should be a black cast Iron dual point distributor with vacuum advance.
Re: correct distributor for 69 gtx [Re: az426john] #980003
04/25/11 02:19 PM
04/25/11 02:19 PM
Arizona
az426john Offline
az426john  Offline
Arizona
The vacuum advance unit should be a little long and have a threaded hex nut end with a nipple on it.
Re: correct distributor for 69 gtx [Re: az426john] #980004
04/26/11 03:07 AM
04/26/11 03:07 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
This is the distributor that is on my '69 4-speed (3.54 Dana) GTX......sorry I can't see the last number of the part number but it's the original I'm pretty sure and from what I could see (but not photograph) it appeared to be a 72.
MikeR
