Rocker arm studs #979722
04/24/11 08:48 PM
04/24/11 08:48 PM
No. cal., sacramento usa
speedy383 Offline OP
I have a couple of studs which have backed off a very small amount,no damage but worries me. Aluminum heads with 1.6 HS roller rockers and RAS shafts with the n/ hold down kit.What can these be torqued to and is thread sealer ok to use?.The nuts didnt back off ,the bolt did and the threads are fine.
Re: Rocker arm studs [Re: speedy383] #979723
04/24/11 11:11 PM
04/24/11 11:11 PM
Anderson, IN
1969RR Offline
1969RR  Offline
Anderson, IN
Speedy383, I've kinda got the same type question too. I bought new Indy EZ'z and they told me to just finger tighten their studs in the heads, no sealer at all. I've seen other studs that said to use sealer or lock-tight. I don't think they should be torqued however. Jeff
Re: Rocker arm studs [Re: 1969RR] #979724
04/25/11 12:26 AM
04/25/11 12:26 AM
Tennessee
steeldust Offline
steeldust  Offline
Tennessee
I have INDY 440-1 heads and i finger tighten them and i had a set of 906s and i tighten them the same i hope this helps good luck.
Re: Rocker arm studs [Re: speedy383] #979725
04/25/11 01:22 PM
04/25/11 01:22 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
FWIW Mine came w/allen heads machined into em so I lightly snugged em down and no problems after several thousand miles and a couple hundred passes.............
Re: Rocker arm studs [Re: Thumperdart] #979726
04/25/11 02:47 PM
04/25/11 02:47 PM
mckinney texas
shoebox Offline
shoebox  Offline
mckinney texas
Studs forthe rocker shafts?
74 dart sport 440 www.Csucarbs.com
Re: Rocker arm studs [Re: speedy383] #979727
04/25/11 02:54 PM
04/25/11 02:54 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
How much spring pressure?
It may be the Heli-Coils in the head compressing?
Re: Rocker arm studs [Re: speedy383] #979728
04/25/11 02:55 PM
04/25/11 02:55 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
I snugged mine and used loctite.
Nautilus Racing-
Re: Rocker arm studs [Re: speedy383] #979729
04/25/11 03:24 PM
04/25/11 03:24 PM
Alexandria, LA
Blucuda413 Offline
Blucuda413  Offline
Alexandria, LA
On my HS system I had a couple bolts work loose so I went to studs. Two studs worked loose the first time I had it out so I resorted to Loctite red and there has been no problem since, about 3 yrs.
Re: Rocker arm studs [Re: Blucuda413] #979730
04/25/11 04:14 PM
04/25/11 04:14 PM
Thanks, i have been told to not use locktite on aluminum? The threads or helicoils are fine. I think i will use some thread sealant and snug them in and keep an eye on them. Its got a Comp roller,255/260 .445.445/ 108 with 1.6 rockers,dont have spring specs with me at this time.
