E BODY CONVERTIBLE ROOF TACKING STRIP #979707
04/24/11 08:21 PM
04/24/11 08:21 PM
Australia
Teamx Offline OP
Teamx  Offline OP
Australia
Hi, Does anyone know of a source for the tacking strip that goes in the track above the rear window glass( the Yearone strip sits too low in the channel)
Thanks Tim
Re: E BODY CONVERTIBLE ROOF TACKING STRIP [Re: Teamx] #979708
04/24/11 09:01 PM
04/24/11 09:01 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
An old "trick" is to size up the profile of a fan belt that will fit into the channel void with a little help from a hammer and drift, the rubber cord of the belt will give you the resiliency to hold the staples when you tack the top on the topbow
Re: E BODY CONVERTIBLE ROOF TACKING STRIP [Re: DAYCLONA] #979709
04/24/11 10:33 PM
04/24/11 10:33 PM
Annapolis, MD, USA
V
Vert Offline
Vert  Offline
V
Annapolis, MD, USA
This is good to know. I'll be using this trick soon.
Re: E BODY CONVERTIBLE ROOF TACKING STRIP [Re: Vert] #979710
04/25/11 10:48 AM
04/25/11 10:48 AM
Washington
69440 Offline
69440  Offline
Washington
I've got a few different thicknesses of that tackstrip, let me know how thich you need it to be, and I'll see if I can help you out. 69440
