how to remove sb distributor gear #979674
04/24/11 07:00 PM
04/24/11 07:00 PM
Missouri
convertriple Offline OP
super gas
super gas
Missouri
I can't get the oil pump/distributor gear out of my sb. What the heck is the secret to pulling it out of the hole???
Re: how to remove sb distributor gear [Re: convertriple] #979675
04/24/11 07:03 PM
04/24/11 07:03 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
no real secret I have always just grabbed it with long needle nose and pulled it out.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: how to remove sb distributor gear [Re: dusturbd340W5] #979676
04/24/11 07:06 PM
04/24/11 07:06 PM
Missouri
super gas
super gas
Missouri
I've been trying that but it wont bring it all the way up before losing its grip.
Re: how to remove sb distributor gear [Re: convertriple] #979677
04/24/11 07:08 PM
04/24/11 07:08 PM
Southern by Choice
Shoozy Offline
I have a foot fetish
Shoozy  Offline
Southern by Choice
Do you have a good strong "magnet on a stick"?
Old, tired, and sometimes broke down. Me, not my car...
Re: how to remove sb distributor gear [Re: convertriple] #979678
04/24/11 07:08 PM
04/24/11 07:08 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
Use big flat head screw driver ...turn clock wise..it will walk up gear...
grab with pliers...
Tony
70 AARCuda Vitamin C
Re: how to remove sb distributor gear [Re: 70AARcuda] #979679
04/24/11 07:22 PM
04/24/11 07:22 PM
Missouri
super gas
super gas
Missouri
My magnet socks, wouldn't pick it up.
The screwdriver trick worked to get it walked up the gear, but not out the hold in the block.
I went back and tried with a different set of short needle nose, and 5 minutes later had it out!
Thanks for the help guys, that was driving me crazy.
Re: how to remove sb distributor gear [Re: convertriple] #979680
04/24/11 08:49 PM
04/24/11 08:49 PM
crlush Offline
crlush  Offline
I use 2 of the bigger craftsman screwdrivers, stick them both In the slot and squeeze both the handles together like a wedge then turn out till its out of the gears then pull up.
