Correct orientation for T/A hood pin plates? #979420
04/24/11 11:54 AM
04/24/11 11:54 AM
BDW Offline OP
BDW  Offline OP
I'm getting ready to install my new T/A hood (AAR Fiberglass).
What is the correct orientation for the 4 holes in the hood pin plate?
Thx
Re: Correct orientation for T/A hood pin plates? [Re: BDW] #979421
04/24/11 12:22 PM
04/24/11 12:22 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Driver's side, taken from the front of the car.
Re: Correct orientation for T/A hood pin plates? [Re: Alaskan_TA] #979422
04/24/11 10:29 PM
04/24/11 10:29 PM
BDW Offline OP
BDW  Offline OP
Thx!
But that pic brings up another question,
Are those rivets?
Re: Correct orientation for T/A hood pin plates? [Re: BDW] #979423
04/24/11 10:38 PM
04/24/11 10:38 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Yes.
Re: Correct orientation for T/A hood pin plates? [Re: Alaskan_TA] #979424
04/24/11 10:43 PM
04/24/11 10:43 PM
BDW Offline OP
BDW  Offline OP
Thx again!
Is there a metal plate on the bottom side of the hood? What does the rivet flare grip to, bare fiberglass?
The kit I bought from Year One has phillip heads screws.
Re: Correct orientation for T/A hood pin plates? [Re: BDW] #979425
04/24/11 10:57 PM
04/24/11 10:57 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
bare fiberglass?
Yep, same hood shown from underneath.
YO used to sell two kits, one with screws for steel hoods & one with rivets for the 'glass hoods.
Re: Correct orientation for T/A hood pin plates? [Re: Alaskan_TA] #979426
04/24/11 11:07 PM
04/24/11 11:07 PM
BDW Offline OP
BDW  Offline OP
Thx so much!
I know enough to be dangerous now.
Re: Correct orientation for T/A hood pin plates? [Re: Alaskan_TA] #979427
04/25/11 12:04 AM
04/25/11 12:04 AM
Virginia, US
RTDaddy Offline
super street
RTDaddy  Offline
super street
Virginia, US
If you're working with an original hood, I would suggeest putting flat washers on the underside of the hood for the rivets to grip, so as not to crack the 'glass. This also works on new hoods.
"IF YOU'RE UNDER CONTROL, YOU AIN'T GOING FAST ENOUGH."
