Vibration Question??? Any Ideas??
#979188
04/24/11 12:54 AM
04/24/11 12:54 AM
Posts: 5,207 Menomonee Falls
DemonDust
Menomonee Falls
I took the duster out for a rip today. I put it to the floor and run thru the gears til about 70. I let off and coasted to the stop sign. About 50 mph it started a real bad vibration then stopped around 35 or so, I'm going by feel no spedo in the car... I went across the intersection and drove to the church to turn around kept it around 35-40 and not a sound. Turned around came back to the stop sign and still not a sound. Left the stop sign was in first gear and hit it went thru the gears to about 70 again and let off and grabbed neutral. Not a sound til about 60 and stopped around 35-40 again... I'm confused on what it could be Anyone ever experience this? When driving under 40 mph it doesn't make a sound...
Re: Vibration Question??? Any Ideas??
[Re: DemonDust]
#979189
04/24/11 01:19 AM
04/24/11 01:19 AM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
what kind of drive shaft do you have? Those drive line vibrations can be a pain to figure out.
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: Sport440]
#979191
04/24/11 01:39 AM
04/24/11 01:39 AM
DemonDust
Menomonee Falls
I have a Dynotech 4" CM .083 1350 u joints.
It was in neutral when it was vibrating. I rev'd the engine and no cchange. It also only vibrated on coast.
Only thing that has changed was a rear brake bracket was cut off and a new one welded on.
[Re: rowin4]
#979193
04/24/11 01:59 AM
04/24/11 01:59 AM
DemonDust
Menomonee Falls
Check the pinion nut.
You think it might be lose and the pinion can ride up the ring gear and cause a vibration?
Thanks for the idea
[Re: DemonDust]
#979194
04/24/11 09:06 AM
04/24/11 09:06 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Thanks for the idea
Check the balance on the tires first(if you can find a Hunter on car balancer to spin them)
[Re: DemonDust]
#979196
04/26/11 01:02 AM
04/26/11 01:02 AM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
Before the Dynotech driveshaft you twisted one didnt you on the launch on ice.
Your car might be a good canidate to do some test Pinion Angle test measurements.
Can you give all the related driveline measurements, for all and both "pinion angle camps" to decipher.
IMO, No doubt you have some angularity problems.
The Evidence, You blew/broke your first shaft and now your having vibration problems with this shaft.
Also, look further then my pinion angle suggestion.
