Lebaron Speedo #979080
04/23/11 09:11 PM
04/23/11 09:11 PM
Crofton, Ky.
rattler Offline OP
rattler  Offline OP
Crofton, Ky.
Hi all, i just bought a 95 Lebaron convert today. On the way home the speedo quit, is there a sensor on the trans or axle? Also, i need the trim around the instrament cluster if you know where i can find that. Thanks, Randy
1957 Dodge truck, Snakeskin Green with a little stroker motor. 1964 Plymouth Savoy wagon ( my new project)
Re: Lebaron Speedo [Re: rattler] #979081
04/24/11 12:14 AM
04/24/11 12:14 AM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
does the cruise control work? odometer work?
Re: Lebaron Speedo [Re: 05dakota] #979082
04/24/11 12:42 AM
04/24/11 12:42 AM
Near Reading PA USA
pinkduster Offline
pinkduster  Offline
Near Reading PA USA
I'd never put myself through that kind of pain again.
Re: Lebaron Speedo [Re: pinkduster] #979083
04/24/11 01:43 AM
04/24/11 01:43 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
There is a sender in the trans, but not in the traditional location. I'd have to check the manual to see which one it is, but like asked above, does the cruise control work? We've got around 160,000 miles on my wife's 95. It's been among the most reliable cars that I have ever owned. We got it seven years ago with 91,000 miles.
Re: Lebaron Speedo [Re: Jim_Lusk] #979084
04/24/11 10:12 AM
04/24/11 10:12 AM
Crofton, Ky.
rattler Offline OP
rattler  Offline OP
Crofton, Ky.
I didn't try the cruise on the way home, but the trip meter and odometer was working because i reset it and watched on the way home. I also noticed the gas gauge didn't fall when you turn the key off. I am going to add 5 gallons to it this morning to see if its stuck or what.
Re: Lebaron Speedo [Re: rattler] #979085
04/24/11 12:55 PM
04/24/11 12:55 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
assuming its a analog cluster, the gear that runs the speedo broke is my guess
Re: Lebaron Speedo [Re: 05dakota] #979086
04/24/11 12:58 PM
04/24/11 12:58 PM
Crofton, Ky.
rattler Offline OP
rattler  Offline OP
Crofton, Ky.
This is an electric speedo, so it either has a sensor or a gear that drives a signal generator.But the question is, where is it located on a front wheel drive car? I have never owned a fwd so this is new to me.
Re: Lebaron Speedo [Re: rattler] #979087
04/24/11 01:17 PM
04/24/11 01:17 PM
Baltimore, MD
MadMax58 Offline
MadMax58  Offline
Baltimore, MD
The speedometer sensor is located on the right (passenger) back side of the trans (facing the firewall).
Re: Lebaron Speedo [Re: MadMax58] #979088
04/24/11 01:20 PM
04/24/11 01:20 PM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
stop by VatoZone, or one of the other parts places, and snag a haynes or chiltons book for the car. it's a decent investment.
Re: Lebaron Speedo [Re: Golden-Arm] #979089
04/24/11 09:36 PM
04/24/11 09:36 PM
Crofton, Ky.
rattler Offline OP
rattler  Offline OP
Crofton, Ky.
Thats what i was thinking, i will pick up a manual for it one day this week. I added 5 gallons of gas to it today and the gas gauge moved on up, so i guess that is working, i just need to fix the speedo so that i can drive it and start working out the bugs. Randy
Re: Lebaron Speedo [Re: rattler] #979090
04/24/11 11:20 PM
04/24/11 11:20 PM
Cookeville
Chilort Offline
Will Work For Mopars
Chilort  Offline
Cookeville
The sender can be bought from any local parts house. The electronics in them are what usually fail. You need an extra elbow in your arm to really get at it from underneath but it can be done.
Re: Lebaron Speedo [Re: Chilort] #979091
04/25/11 12:17 AM
04/25/11 12:17 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
If the odometer was working the sender (speed/distance sensor) is fine. Also, by 1995 the S/D sensor is NOT located on the right back of the trans (extension housing for the right axle).
Re: Lebaron Speedo [Re: Jim_Lusk] #979092
04/25/11 08:18 AM
04/25/11 08:18 AM
Crofton, Ky.
rattler Offline OP
rattler  Offline OP
Crofton, Ky.
So, because the odometer is working, that means the gauge has issues? Just trying to be sure on this.
Re: Lebaron Speedo [Re: rattler] #979093
04/26/11 08:00 PM
04/26/11 08:00 PM
MINNESOTA
BRONZEBEE Offline
BRONZEBEE  Offline
MINNESOTA
3 speed or 4 speed?if it shifts ok its the cluster.if the speedo does not work its the output speed sensor on the front of the transmission facing the radiator(unless you have a broken wire).There are two sensors,it will be the one one the drives side.if its a 3 speed sensor is on the passenger side housing of the transmission.
Re: Lebaron Speedo [Re: BRONZEBEE] #979094
04/27/11 02:00 AM
04/27/11 02:00 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
95's were ALL 3.0 and all autos in 95 (I don't know the last year for the manual trans) were the overdrive (four forward gears).
Re: Lebaron Speedo [Re: Jim_Lusk] #979095
04/29/11 12:02 AM
04/29/11 12:02 AM
Crofton, Ky.
rattler Offline OP
rattler  Offline OP
Crofton, Ky.
Update, we got the car out this evening and after a little while of driving around, the speedo started working again. I figure it must be a short somewhere or the car is starting to like me.
