68 Hemi air cleaner base plate Correct? #97846
07/31/08 08:17 PM
07/31/08 08:17 PM
Fairfield Maine
hemi4speed Offline OP
Fairfield Maine
Is this base plate correct for 68 Hemi, It has a vent tube and also an indent on the other end. Reason I ask is it hits my throttle linkage,(on stock carbs)
Re: 68 Hemi air cleaner base plate Correct? [Re: hemi4speed] #97847
07/31/08 09:35 PM
07/31/08 09:35 PM
Fairfield Maine
Fairfield Maine
Anyone?
Re: 68 Hemi air cleaner base plate Correct? [Re: hemi4speed] #97848
07/31/08 09:41 PM
07/31/08 09:41 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
It looks correct, sounds like your linkage is either incorrect or installed wrong, are you sure the carbs are originals?
Re: 68 Hemi air cleaner base plate Correct? [Re: ScottSmith_Harms] #97849
07/31/08 10:25 PM
07/31/08 10:25 PM
Fairfield Maine
Fairfield Maine
Yes Scott, its the Carbs you restore for me, all original linkage.
Rick
Re: 68 Hemi air cleaner base plate Correct? [Re: hemi4speed] #97850
07/31/08 10:31 PM
07/31/08 10:31 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
I see the problem, linkage arm is reversed, copy this one and you'll be good
Re: 68 Hemi air cleaner base plate Correct? [Re: ScottSmith_Harms] #97851
07/31/08 10:32 PM
07/31/08 10:32 PM
Fairfield Maine
Fairfield Maine
thanks Scott
