Cometic Head Gaskets #978409
04/22/11 10:14 PM
04/22/11 10:14 PM
usa
9
90ram Offline OP
90ram  Offline OP
usa
What Part number is best to Use with a 4.500 Bore
On their Web sight they list 5 different thickness, Do the thicker ones seal better?
Re: Cometic Head Gaskets [Re: 90ram] #978410
04/22/11 10:55 PM
04/22/11 10:55 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
I don't know about sealing better , but the thicker gaskets are used to set quench and determine static compression ratio.
edited to add.........I should say different thicknesses to set and determine.
Re: Cometic Head Gaskets [Re: 90ram] #978411
04/22/11 11:46 PM
04/22/11 11:46 PM
Tennessee
steeldust Offline
steeldust  Offline
Tennessee
I am building a 572 with 4.500 bore and i got a set of part number #C5799 they are 0.40 thick if your block and heads are right they will seal.I have a aluminum block and heads . I hope this helps good luck.
Re: Cometic Head Gaskets [Re: steeldust] #978412
04/22/11 11:52 PM
04/22/11 11:52 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
I would use permatex copper spray on the cometic gaskets
1.39 9.85 - 137 mph
Re: Cometic Head Gaskets [Re: Ari440] #978413
04/23/11 12:16 AM
04/23/11 12:16 AM
glendora, ca.
Deepockets Offline
Deepockets  Offline
glendora, ca.
i just pulled my invoice from them, H1637SP3040its listed as a 4.530 bore. this is what i used with the 4.500 bore as per there recommdation.
Re: Cometic Head Gaskets [Re: Deepockets] #978414
04/23/11 01:51 AM
04/23/11 01:51 AM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Customs is what I have always done. Wast no more money...
I added .060 to my Hemi for a gasket bore or 4.56, adjusted the thickness to whatever.. Like .035 or so...
They are tough. First on the Wedge I used the copper spray, didnt like how they torqued, which was spongy, and lost torque a bunch.
On the hemi I installed them dry and just added a bottle or Bars Stop Leak.
Never a problem
Re: Cometic Head Gaskets [Re: Bob_Coomer] #978415
04/23/11 10:14 AM
04/23/11 10:14 AM
NJ central
Scamp408 Offline
Scamp408  Offline
NJ central
Put the copper spray or a little copper rtv around water ports and do a retorque after some hot/cold cycles I dont care what they say (no retorque required)
